Toymods » Tech & Conversions » 18RG Aircon
RA28midge
Adelaide and Queenstown T...
18RG Aircon Wed, 14 January 2004 03:09 Go to next message
Are there any known replacement compressors that people have used instead of the original 18RG.
Same for bracket assembly to bolt onto head.
A
BarniesRA40
Hobart, Tasmania
Re: 18RG Aircon Wed, 14 January 2004 09:52 Go to previous messageGo to next message
I'm searching high and low for the same thing. It seems that spares for Air Con mounted onto an 18RG are impossible to get.
If I can get some original 18RG Air Con brackets I could probably get a hybrid mount cast that would fit a Compressor from an 18RC onto an 18RG.
Re: 18RG Aircon Wed, 14 January 2004 11:05 Go to previous message
my g/friends father ended up welding/fabricating a mount out of mild steel rather than attempt to locate a factory item.
you're only bolting to four points on the compressor and from memory it attaches at three points on the head? you would also have to fabricate an idler pully mount. you could probably adapt the adjuster mechanism from an 18RC aircon for this.
choice of location of adjuster is yours - but idler pulley will be safer location (if you wear the bearing out in the compressor it costs you a lot more than another idler pulley.
charles
Previous Topic:Found a weird car, i need some info.
Next Topic:ta22 exhaust, manifold
Current Time: Sat Nov 21 04:23:09 UTC 2026
Total time taken to generate the page: 0.0042369365692139 seconds
