Classifieds » Miscellaneous » SOLD TO4 turbo
91golux
mackay
icon14.gif  SOLD TO4 turbo Wed, 14 January 2004 12:41 Go to next message
The TO4 has just been rebuilt and re kitted with new bearings , seals etc. It comes with all gaskets, dump pipe, v band clamp and a 32mm external wastegate.
The turbo has a .84 turbine housing with a 'P'trim wheel and a rare cat 4"entry .6 comp housing with a 'H'trim wheel.
Phone Jeff 0407112741.
$1100 ono
http://forums.toymods.org.au/index.php?t=getfile&id=2877http://forums.toymods.org.au/index.php?t=getfile&id=2880
Attachment: turbo4.jpg
(Size: 31.69KB, Downloaded 391 time(s))
Attachment: turbo1.jpg
(Size: 27.94KB, Downloaded 384 time(s))
[Updated on: Tue, 27 January 2004 12:38]
91golux
mackay
Re: TO4 + 32mm garret gate Wed, 14 January 2004 12:43 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=getfile&id=2881http://forums.toymods.org.au/index.php?t=getfile&id=2882http://forums.toymods.org.au/index.php?t=getfile&id=2882
(Size: 27.94KB, Downloaded 11 time(s))
Attachment: turbo2.jpg
(Size: 30.61KB, Downloaded 376 time(s))
Attachment: turbo3.jpg
(Size: 31.67KB, Downloaded 375 time(s))
[Updated on: Wed, 14 January 2004 12:52]
91golux
mackay
pictures Wed, 14 January 2004 12:45 Go to previous messageGo to next message
No Message Body
[Updated on: Wed, 14 January 2004 12:56]
TE72_Turbo
Re: TO4 + 32mm garret gate Thu, 15 January 2004 07:08 Go to previous messageGo to next message
Would you separate the gate? how much?
knackers
berala sydney
Re: TO4 + 32mm garret gate Thu, 15 January 2004 17:42 Go to previous messageGo to next message
hi what sort of hp will this turbo make
knackers
sprinterboy4agze
Re: TO4 + 32mm garret gate Thu, 15 January 2004 23:56 Go to previous messageGo to next message
and when do u think it would come on boost? on a 4agze block
Sprinta
Re: TO4 + 32mm garret gate Fri, 16 January 2004 00:25 Go to previous messageGo to next message
Are you kidding me sprinterboy?
Probably never ! or around 6000 haha
Its a bullshit good turbo but more suited to a bigger engine..
Good luck with the sale !
91golux
mackay
Re: TO4 + 32mm garret gate Fri, 16 January 2004 06:16 Go to previous messageGo to next message
This would be lucky to come on at 6500 on a 4ag, Its just far too big. Much more suited for a 1j/2j, rb, or any 6 or rotary.
As it goes for HP the turbo is rated at around 450hp. So can easily produce 250rwkw.
tin can
Re: TO4 + 32mm garret gate Fri, 16 January 2004 11:58 Go to previous messageGo to next message
how well it go on a 3 cyl blow though carby type g102
91golux
mackay
Re: TO4 + 32mm garret gate Fri, 16 January 2004 12:58 Go to previous messageGo to next message
maybe if you bolted two of them together you might have a chance. But iff not, not a chance.SORRY
Allan
Re: TO4 + 32mm garret gate Fri, 16 January 2004 15:43 Go to previous messageGo to next message
Thats one huge bitch!
slydar
Re: TO4 + 32mm garret gate Sat, 17 January 2004 00:56 Go to previous messageGo to next message
B or E ? split pulse? trim? a/r?
91golux
mackay
Re: TO4 + 32mm garret gate Sat, 17 January 2004 12:35 Go to previous messageGo to next message
It is a T04 B, it has a split pulse.84 ar with a p trim wheel and a h trim comp wheel.
supra1jz
Launceston, Tasmania
Re: TO4 + 32mm garret gate Sun, 18 January 2004 05:26 Go to previous messageGo to next message
What were you running this turbo on? I'd like to know when it would spool up on a 1jz. I really like the factory ct12a's because they spool up so early and I would hate to lose that low down torque they provide. Please tell me when it made meaningful boost on your motor, rpm wise. I take it this is not a BB core either.
Rich
Chris Davey
sunny coast, qld
Re: TO4 + 32mm garret gate Sun, 18 January 2004 13:43 Go to previous messageGo to next message
as far as i can tell, this is a very similar turbo to the one that another fella was using on his 1jz which he said made 400rwhp. The only difference I can see is the comp wheel is .6AR and the other one was a 60-1 .7AR. Both have same exhaust housings.
SO same exhaust housings but slightly smaller compressor AR, does this mean it would spool up a bit earlier or just run out of puff a little earlier?
91golux
mackay
Re: TO4 + 32mm garret gate Mon, 19 January 2004 11:11 Go to previous messageGo to next message
The smaller comp cover and wheel does mean it will run out of puff a little earlier, but it does also mean it will come on earlier, and be a little more responsive.
The cat comp cover this turbo has, has about 6mm more alloy in its cast, so it can be power ported to the same internal size as a .7 comp. It also has an 4" inlet unlike the standard 3".
[Updated on: Mon, 19 January 2004 11:17]
91golux
mackay
icon14.gif  SOLD TO4 turbo Mon, 19 January 2004 11:35 Go to previous message
By the way the turbo set up also comes with an adaptor that bolts the wastegate director to the turbo.http://forums.toymods.org.au/index.php?t=getfile&id=2945
Attachment: adaptor.jpg
(Size: 25.76KB, Downloaded 85 time(s))
[Updated on: Tue, 27 January 2004 12:36]
Previous Topic:House to rent
Next Topic:Must sell
Current Time: Tue Oct 27 10:14:59 UTC 2026
Total time taken to generate the page: 0.0069980621337891 seconds
