Toymods » Tech & Conversions » Stud Pattern
ke20 guy
Stud Pattern Wed, 14 January 2004 13:34 Go to next message
hey there, figured this is hopefully the best place to get info. i need the specs on RA60 celica stud pattern as in what size wheel and stuff is required for them! probably a stupid question but i need a new set of rims, with a nice offset.
Regards
Ray
Re: Stud Pattern Wed, 14 January 2004 13:36 Go to previous messageGo to next message
The factory RA60 rims are 14x5.5" with a 4x114.3 stud pattern and a roughly +20mm offset.
slydar
Re: Stud Pattern Fri, 16 January 2004 00:15 Go to previous messageGo to next message
which means often silvia rims will fit. (i have had import wheels on ra60 struts in my last sprinter). so go down to your local import wrecker and see if theres anything you like.
i did have to use a thin spacer to stop the tire rubbing on the strut leg. but this was with crappy 60 (or maybe 65 series) rubber.
[Updated on: Fri, 16 January 2004 00:24]
Re: Stud Pattern Fri, 16 January 2004 00:17 Go to previous message
The Silvia rims are about 35mm offset, so while they will fit, it is likely they will rub, the offset is just *too* great.
Previous Topic:GA61 Suspension
Next Topic:MA61 KYB shock offical info
Current Time: Tue Nov 24 11:10:11 UTC 2026
Total time taken to generate the page: 0.0043380260467529 seconds
