Toymods » Tech & Conversions » how big is big {cams}
Mr DOHC
how big is big {cams} Thu, 15 January 2004 08:31 Go to next message
what would u consider these cams to be in regards to stage 1/2/3 ect
18rg
inlet 288 deg
exh 272 exh
not sure of lift tho
does anyone know cam specs for 88250 or 88270
Re: how big is big {cams} Thu, 15 January 2004 08:50 Go to previous messageGo to next message
Assuming the lift is also increased, 288 is starting to mean business and might be just a touch tricky for the street. 272 is teh ghey. Your standard 18RG will have a duration of around 230-240 degrees.
Need also to know the duration @ 50 thou and lift before we could make a definite comment.
clubagreenie
1st street on the right
Re: how big is big {cams} Thu, 15 January 2004 09:54 Go to previous messageGo to next message
Biggest 18rg cams I've seen (still called, questionably, streetable) were 304's at 10.5mm. Quite large but were std TRD items. Would need some expansion of breathability to work.
Mr DOHC
Re: how big is big {cams} Thu, 15 January 2004 11:03 Go to previous messageGo to next message
i'm trying to get the lift off the guy
V8_MA61
Re: how big is big {cams} Thu, 15 January 2004 11:06 Go to previous messageGo to next message
my cam is 596' Razz
people100
Rocklea qld
Re: how big is big {cams} Thu, 15 January 2004 11:10 Go to previous messageGo to next message
i had a 18rgu and was told the cams in it were 350. would that be correct. It ran really lumpy so i always assumed it was right.
Re: how big is big {cams} Thu, 15 January 2004 11:21 Go to previous messageGo to next message
people100 wrote on Thu, 15 January 2004 22:10
ahhh, you mean degrees??? hmmm, lets see. what happens if a cam is open for 350 cranks degrees? ahhhh......
as for streetable cams, ppl have different ideas. i think streetable has to idle at 1500rpm or less
the 277/284 (50 thou 231/235) 435thou lift cams in my 4K are still streetable with 10.2CR
anything more i think would be a little much too live with, unless you -really- wanted to...
but yeah, 288/277 soudns good (tho mine are other way round)
ps, mine is/are 'stage 4' camtech cam, out of 7 stages. last streetable one tho.
CelicaRA45
nth ringwood, Victoria
Re: how big is big {cams} Thu, 15 January 2004 11:55 Go to previous messageGo to next message
the 304 and 288 are rally grinds that trd did for 2tg and 18rg you need to no what they are at 50thou at around 260 onwards gets up to 3/4 race should still idle at 1000 rpm and still at 10.5 lift is small .trd did some race cams for both motors 420 thou and 440 thou lift but 320 duration and they went to 8000 so power from 4500 upwards ,on the subject of lift im running 535 thou or 13.5 lift with 296 duration but at 50thou they are 268 and it idles at 750 rpm
T APLUS 22
Re: how big is big {cams} Thu, 15 January 2004 14:02 Go to previous messageGo to next message
totally unnecessary..however I know approximately shit all about Cams. Smile
Re: how big is big {cams} Fri, 16 January 2004 00:24 Go to previous messageGo to next message
CelicaRA45 wrote on Thu, 15 January 2004 22:55
interesting. with my cams, i lose vacuum at about 1200rpm, and my power band is from 4000-8000+ (DD5)
what vacuum do you have with those cams at 750rpm? i'm assuming you're injected? what motor (pardon me if i should know already Wink )
just curious how you get the thing to idle..
oh, and is it smooth idle, or lopey idle... i consider idling to be where there is minimal missing, and smooth running, not like V8 drag idle, wher it fires every 2 or 3 rpm Wink (that that always does sound nice Very Happy )
Mr DOHC
Re: how big is big {cams} Fri, 16 January 2004 06:58 Go to previous messageGo to next message
[quote title=oldcorollas wrote on Fri, 16 January 2004 10:24]
whats wrong with that Razz , i love the sound of a good lumpy V8 idle, odes anyone know the maximum allowable lift for a 18RGU
CelicaRA45
Re: how big is big {cams} Fri, 16 January 2004 07:01 Go to previous messageGo to next message
only run vacuum to no 4 cyl and the idle is fine mine also is 2litre 3sge beam engine with trd parts through it
Re: how big is big {cams} Fri, 16 January 2004 07:18 Go to previous messageGo to next message
philmelvin wrote on Fri, 16 January 2004 17:58
[/quote]
umm... kind alike the rotary crap idle but much slower.. like
vrrm...........vrrrm..........vrrrm..........vrrrm .........
not lumpy where it burbles Wink, more like where it is firing maybe 1/3rd of the time....
CelicaRA45. i meant actual MAP value... and, yeah, shouldve looked at your sig Wink
i think you are in a different world to most of us as far as engine manners goes Wink Very Happy
V8_MA61
Re: how big is big {cams} Fri, 16 January 2004 10:15 Go to previous messageGo to next message
mmmm lumpy cam Smile I was at my engineers work the other day, and was watching a car they had just put a 351w into...at idle the whole front of the car shook..i was like whoa! Shocked Almost got the tyres on fire when he took off.
Mine wont start to get real angry until 3k, the cam becomes alive then..should go out to 8500 hopefully. But it is pretty wild. Sig erson brand
Mr DOHC
Re: how big is big {cams} Fri, 16 January 2004 11:17 Go to previous messageGo to next message
the menice race team has a 854 thou lift cam in their cortina drag car Very Happy
V8_MA61
Re: how big is big {cams} Fri, 16 January 2004 11:24 Go to previous messageGo to next message
oooooo...nice! A little "too wild" for the streets i think... Smile
Mr DOHC
Re: how big is big {cams} Fri, 16 January 2004 11:28 Go to previous messageGo to next message
have u ever seen the cam outta a top fueller, the lobes are oblong basically, not tear drop
V8_MA61
Re: how big is big {cams} Fri, 16 January 2004 11:29 Go to previous messageGo to next message
Laughing pretty grouse arent they Wink
Re: how big is big {cams} Fri, 16 January 2004 11:59 Go to previous message
heh heh, amazing what you can do with roller gear Cool
pity they don't make roller lifers and rockers for K motors, might wring another couple of Krpm from it Wink
Very Happy Very Happy
Previous Topic:NA cams in a 4agze
Next Topic:quick tech question. Please help.
Current Time: Mon Nov 23 14:57:49 UTC 2026
Total time taken to generate the page: 0.0064260959625244 seconds
