Toymods » Tech & Conversions » 3sge afm to map
ogip
Phils
3sge afm to map Thu, 15 January 2004 16:46 Go to next message
I will convert my 1st gen 3sge tvis AFM to MAP. i will be using the 2nd gen ecu to convert it. My 3sge is in RT132 corona rwd. The afm is to bulky so i decided to use map sensor.
i know it will run and i must disable the tvis bec. the ecu has no trigger for the tvis
is anybody here done it? what is the effect?
any comments on this? Very Happy
Classique71
Colac, Victoria
Re: 3sge afm to map Fri, 16 January 2004 01:48 Go to previous messageGo to next message
Give wolfEMS a call - they have doen a few 3sge swaps as far as i know in later model MR2's so they should know what ECU to run and what would need to be changed .
They are swapping my AFM 3sgte to map when they install my new ECU in a few weeks , so i cant see why they cant do it for a 3sge.
bbaacchhyy
Re: 3sge afm to map Fri, 16 January 2004 02:25 Go to previous messageGo to next message
From what I know, Gen 2 is still AFM. Gen 3's had the MAP sensor in it.
The MR2T rear cut that I had with the Gen 2 was still AFM
Michael B
ogip
Phils
Re: 3sge afm to map Fri, 16 January 2004 16:11 Go to previous message
thanks for your reply.
the ecu that i got is map.
my friend 3sge that I installed is map,i have the same ecu that he have. so i planned to convert my afm to map
Previous Topic:2TG Engine Rebuild Gasket Kit ????
Next Topic:tacho dies in hot weather
Current Time: Fri Nov 20 18:36:38 UTC 2026
Total time taken to generate the page: 0.060583114624023 seconds
