Toymods » Tech & Conversions » quick one, will my 4AC starter motor bolt onto a JDM AE86 bellhousing
shinybluesteel
melbourne
quick one, will my 4AC starter motor bolt onto a JDM AE86 bellhousing Thu, 15 January 2004 22:24 Go to next message
hey all, as the title suggests, will this be possible?
i'm pretty sure it will, but need to know if i need to hassle the guy for his old starter motor too.
Re: quick one, will my 4AC starter motor bolt onto a JDM AE86 bellhousing Fri, 16 January 2004 00:31 Go to previous messageGo to next message
Hmm it'd kinda be upside down wouldn't it.
Assuming you can still get the cables on it would imagine it'd be ok.
shinybluesteel
melbourne
Re: quick one, will my 4AC starter motor bolt onto a JDM AE86 bellhousing Fri, 16 January 2004 00:52 Go to previous messageGo to next message
huh? is it on the other side? dammit, this is getting (understandably) more complicated by the second.
im going to look through my pics and manuals i think.
just hope i can score starter too
the alternator is on the other side, but i dont think that should be a problem, ill see if the 4ac one fits anyway i think, cause i know it works.
cheers joel
[Updated on: Fri, 16 January 2004 01:03]
Re: quick one, will my 4AC starter motor bolt onto a JDM AE86 bellhousing Fri, 16 January 2004 01:16 Go to previous messageGo to next message
My understanding is the only difference in JDM bellhousing is starter and possibly clutch (not sure) is on the driver side.
The 4AC had exhaust on driver side, so makes sense for starter to be out of the way on the passenger side. But 4AGE exhaust being on passenger side, they put the starter on driver side.
Re: quick one, will my 4AC starter motor bolt onto a JDM AE86 bellhousing Fri, 16 January 2004 01:20 Go to previous messageGo to next message
As for the alternator... The 4AC one uses a single V belt. The 4AGE one has those ribbed ones. Also the different in 4age being internally regulated whereas 4ac is external reg.
I'm trying to remember what I did now when I converted mine. I used an AE82 FWD 4AGE though so all a bit different.
I know I used the 4AGE alternator, but as for brackets... Think I just left it on the original 4AGE brackets. I can confirm that for you tonight if you wanted.
shinybluesteel
melbourne
Re: quick one, will my 4AC starter motor bolt onto a JDM AE86 bellhousing Fri, 16 January 2004 01:40 Go to previous messageGo to next message
well i know for a fact that the JDM bellhousing has the clutch on the drivers side, or the "away from the exhaust" side, and its on the passenger side of the poverty spec model.
this is the thing i am concerned about, the extractors that came with the engine supposedly will not fit with the australian spec bellhousing, if i was doing the exhaust myself i would just use the bellhousing and starter motor i have.
as far as the alternator goes, thanks for the offer, but dont bother checking, if the 4ac one fits and i can change the pulley i may fit it, but it is really a small problem.
if it is internally regulated, i can piss off the voltage regulator, weight reduction! woo hoo.
the alternator is on the drivers side of the engine, you cant use the 4ac brackets because the tensioning bracket bolts onto the totally different head.
thanks again
shinybluesteel
melbourne
Re: quick one, will my 4AC starter motor bolt onto a JDM AE86 bellhousing Sat, 17 January 2004 11:11 Go to previous message
kinda bump, checked through the AE86 chassis manual, and it shouws the starter on the passenger side, so all should be good.
funny thing, the JDM clutch fork appears fairly different from the australian one, apart from being on the other side that is
Previous Topic:4wd and LSD's - advice needed
Next Topic:GA-6X cross-member configuration (and others)
Current Time: Fri Nov 20 13:35:15 UTC 2026
Total time taken to generate the page: 0.0047340393066406 seconds
