Toymods » Tech & Conversions » Oil flow in 4age
westy1
Perth wa
Oil flow in 4age Fri, 16 January 2004 01:18
Can anyone advise on my oil flow problem in a 4age -100kw, no oil cooler. When I removed the oil filter it was dry i.e. no oil circulating through it for approx 3000km.The pressure gauge showed all was OK during this time and I know there was oil getting to the cams etc. The engine is sound and there was no excess metal in the sump oil. When I cranked the engine with the filter off oil flowed from the block. Screwed the filter back on and it filled with oil. Is the flow a by-pass set up that allows oil to flow to the engine as well as the filter? Anyone else had a similar problem?
thanks in advance
Previous Topic:ke11 disc brake conversion
Next Topic:Charge light coming on with ignition off - RA23
Current Time: Sun Oct 11 22:30:23 UTC 2026
Total time taken to generate the page: 0.041072130203247 seconds
