Toymods » Tech & Conversions » Camber adjustment
wilbo666
Camber adjustment Fri, 16 January 2004 01:58 Go to next message
Ok, well I'm looking into camber adjustment now (have sa63 struts in mx62) as I'll be lowering the car shortly...
As I see it I have two options
1: Adjustable strut tops
2: Adjustable lower control arms
How exactly do I modify the lower control arm to make it adjust the camber (anyone have pics / approx price?), and how much camber adjustment will be possible (a wild guess will do...). Also what is rose jointing, from what I could find its replacing the rubber bush with a metal / metal fitting....(can anyone explain this better / have a photo :S)
Also what other cars have a strut top with 100mm bolt center to center? (ae86?)
Re: Camber adjustment Fri, 16 January 2004 02:54 Go to previous messageGo to next message
Adjusting the camber from the lower control arms is usually acheived using camber bolts in place of the regular bolts which attach the control arm to the crossmember. It's an eccentric bolt so as you turn it it moves the position of the control arm. Note that this method will have an effect on the track width, so be aware of wheel clearance. You may not have a choice though; generally speaking you don't get much movement from adjustable strut tops, and in your case it may be insufficient.
Another method is getting the struts bent. Apparently this is pretty common in racing circles, but I'm not sure if it's technically legal on the street. Not that anyone would know! Smile
shinybluesteel
melbourne
Re: Camber adjustment Fri, 16 January 2004 05:13 Go to previous messageGo to next message
i take it you have enough negative camber and dont want more after you lower it?
camber plates are probably easier, you can get the lower control arms replaced with adjustable ones, but im not sure how expensive they would be.
roll centre adjusters would keep the camber the same, and maintain "proper" suspension geometry, i'm a bit concerned about this, as i like the amount of camber my car has at the moment (from lowering it) but when i fit RCAs all my free negative camber will dissapear. oh well.
wilbo666
Re: Camber adjustment Sun, 18 January 2004 09:28 Go to previous messageGo to next message
Well I have the SA63 struts (with MA61 stock springs) in now and have 0.3 +ve on the left and 0.3-ve on the right Confused I guess I'll wait and see what it is when I lower it, then maybe get a strut bent to fix it so they are the same...norbie do you know how much your camber changed when you lowered yours?
I inquired about an eccentric bolt for the lower control arm and was told one wasn't available Rolling Eyes
Also I was planning on getting RCA's so that will bring me closer back to what I have now (and I'd like 1 -> .6 or so -ve camber)...
ae86drift
sydney.au
Re: Camber adjustment Sun, 18 January 2004 09:41 Go to previous messageGo to next message
shinybluesteel wrote on Fri, 16 January 2004 16:13
problem solved
http://www.technotoytuning.com/t3_site_pages/produ cts/ncrca.html
gold28
Madrid - Spain
Re: Camber adjustment Sun, 18 January 2004 11:01 Go to previous messageGo to next message
In line with what Norbie is suggesting, I have a variation on the eccentric control arm bolts, only my chassis mount was drilled out and an eccentric bush installed to move the hole outward. Fairly easy mod and effective if you only want a modest change in camber.
wilbo666
Re: Camber adjustment Mon, 19 January 2004 07:26 Go to previous messageGo to next message
gold28 wrote on Sun, 18 January 2004 22:01
This idea I like, how expensive was it?
Brenton_TA23
Re: Camber adjustment Mon, 19 January 2004 07:35 Go to previous messageGo to next message
I had my struts bent by pedders suspension. they are licensed to do it legally but i dont know yet how reliable this method is. i had +.06 L and +.06 R now i have -.25 L and -.55 R. It made a big difference.
wilbo666
Re: Camber adjustment Mon, 19 January 2004 07:44 Go to previous messageGo to next message
when they bend the struts, I'm guessing that they have to take them out of the car?
I'd like some form of adjustably really tho...
Brenton_TA23
Re: Camber adjustment Mon, 19 January 2004 07:49 Go to previous messageGo to next message
you can bend them more, they wanted to but i wasn't keen. They don't need to take the struts out they just take the wheels off.
gold28
Madrid - Spain
Re: Camber adjustment Mon, 19 January 2004 20:40 Go to previous message
Sorry I can't give you a price as it was done before I got the car. I wouldn't have thought it would be too expensiveas as they would be a really cheap part to buy/make and it would only take maybe an hour tops to install. Plus an alignment of course.
Previous Topic:Update on the soarer - Smiles all round really
Next Topic:Do 5M's have the same problem as 7M's?
Current Time: Tue Nov 3 18:51:01 UTC 2026
Total time taken to generate the page: 0.011584997177124 seconds
