Toymods » Tech & Conversions » PROBLEM 4AGE into AE86
RedAe86
PROBLEM 4AGE into AE86 Fri, 16 January 2004 09:03 Go to next message
I have already fitten the engine and driven it but the cluch would not work correctly it would crunch.
I have
100kw Twin cam ae92 8 bold crank
86kw twin cam ae82 flywheel 8 bolt
and an ae82 twin cam cluch and thrust bearing
it seams like the thrust bearing does not push the pressure plat enough with another thrust bearing it works better but it has a large space that come off the side that hits the pressure plate. it is wrong and has to much play! anyone know whats going on?
or what to use!
mabey i have the wrong cluch fork?
danielc
Re: PROBLEM 4AGE into AE86 Fri, 16 January 2004 09:16 Go to previous messageGo to next message
sounds like pushrod adjustment... if you dont have enough adjustment youll have to make a longer pushrod. that should fix it
IRA11Y
Club Member
Re: PROBLEM 4AGE into AE86 Fri, 16 January 2004 10:50 Go to previous message
are you sure you have the clutch plate around the right way Rolling Eyes
or is the 100Kw (212?) clutch plate not matching to the 86Kw (200mm) flywheel
[Updated on: Fri, 16 January 2004 10:53]
Previous Topic:18R Bottom End vs 18RG Bottom End
Next Topic:ma61 diff rebuild
Current Time: Sun Oct 18 17:57:19 UTC 2026
Total time taken to generate the page: 0.0041980743408203 seconds
