Toymods » Tech & Conversions » quick tech question. Please help.
people100
Rocklea qld
quick tech question. Please help. Fri, 16 January 2004 10:34 Go to next message
a mate of mine has a hilux with a 4cyl in it. I think it is a 3y the same as the early taragos. It started and then stopped and hasnt started again. it has good spark at the coil and good but sometimes irratice spark at the plugs. We replaced the cap and rotor and cleaned and regapped the points and plugs. It also has fuel at the carby. We stuck fuel down the throat and it fires but doesnt run. What things should we check. Ballasrisistyor, coil etc. has anyone else had this problem.
Mr DOHC
Re: quick tech question. Please help. Fri, 16 January 2004 11:06 Go to previous message
pull the plugs out and make sure fuel is getting to the cylinders, whenthe plugs r out wind it over, it fuel spurts out the holes then u r getting fuel.
check the leads for arcing and test them with a multimeter for continuity
just remember, fuel, air, spark, all u need for a running engine
Previous Topic:how big is big {cams}
Next Topic:18R Bottom End vs 18RG Bottom End
Current Time: Mon Nov 23 15:03:53 UTC 2026
Total time taken to generate the page: 0.0037460327148438 seconds
