Toymods » Tech & Conversions » 4agze air/con
horner boy
4agze air/con Sat, 17 January 2004 04:20 Go to next message
I'm putting the ze in my sprinter. Did these come with air? How hard is it to fit? Does anyone know where I can get one?
horner boy
Re: 4agze air/con Tue, 24 February 2004 05:55 Go to previous messageGo to next message
uhh guys????? Anyone there?
Rod83
Re: 4agze air/con Tue, 24 February 2004 08:47 Go to previous messageGo to next message
The gze's came with aircon, might have been an option though. I'm sure someone has one lying around, just put a wanted ad for the compressor here and at twincam.org. To fit it you'll need the condensor as well. You'd then need custom pipes to run from the compressor to the condensor and then to the interior, as the standard ones for the gze will probably be different.
I've probably missed some parts here but I think those are the major ones.
JDM hachi
was adelaide now newcastle
Re: 4agze air/con Wed, 25 February 2004 06:13 Go to previous messageGo to next message
most of the system will not be a problem, just the lines from the compressor will need to be custom made, cant use standard ones because the ends that bolt to the compressor face the wrong way, if you could weld the ends of the gze ones to the standard lines you should be in business (you must use the gze compressor, as it bolts on differently due to the superchargers belt arrangement, could use it on a gte though i suppose), the only other problem comes from the electronics which controll the a/c, i did mine to a point where i thought it might work, but since i didn't have the custom lines, it would not work (must be pressure in the system for the a/c electronics to let the a/c work)
matty.
horner boy
Re: 4agze air/con Wed, 25 February 2004 09:46 Go to previous message
thanks guys
Previous Topic:2JZ-GTE VVTi
Next Topic:Who sells remote oil filter kits(z386)
Current Time: Sat Oct 17 03:43:29 UTC 2026
Total time taken to generate the page: 0.0097289085388184 seconds
