Classifieds » Parts Wanted » 4.3:1 crown & pinion
Jonny2TG
Tasmania
4.3:1 crown & pinion Sat, 17 January 2004 14:23 Go to next message
Wanted, 4.3:1 or low ratio diff gears to suit my T series 6.7" diff please. Currently got 4.1:1 but I want something lower. I know 4.3:1 is avaliable, but rare.
ta2272
Re: 4.3:1 crown & pinion Sat, 17 January 2004 14:59 Go to previous messageGo to next message
hey just wondering is this will give you much better acceleration i am thinking of going the same way.
jason
Jonny2TG
Tasmania
Re: 4.3:1 crown & pinion Sun, 18 January 2004 00:45 Go to previous message
No a different diff ratio won't magicaly give me better acceleration, but it will lower all the gear ratios and bring them closer together. Top speed will be slightly lower, but still about 200km, but the gears should be closer together (Less rpm drop when you change gears). When I use my 305 cams, I expect the powerband will be narrower so I want closer ratios for the track. A low ratio diff is cheaper than a close ratio gearbox!
Previous Topic:SWAP gbox for carbs
Next Topic:WTB: 15" rims for Sprinter
Current Time: Wed Oct 14 09:51:01 UTC 2026
Total time taken to generate the page: 0.038712978363037 seconds
