Toymods » Tech & Conversions » ma61 bugs
boudan
ma61 bugs Sun, 18 January 2004 13:21 Go to next message
1. The gearstick "bites" as it moves through the selectors
- is this a sign that the selectors are buggered or something else.. perhaps worn syncros? My only option is a rebuild or replacement ?
2. The brakes / steering squeak as if some / all the bushes are completely worn through
Will replacing the bushes remedy this squeal - (not worn brake pads)
Re: ma61 bugs Sun, 18 January 2004 13:42 Go to previous messageGo to next message
1. clutch may not be fully disengaging? or synchro's not up to scratch
if internal to the gearbox - dump g/b oil and replace with thicker or better oil - might delay the need to rebuild.
2. worn bushes would also manifest themselve thru shit handling - i owuld start with checking/greasing/replacing any ball joints first - before looking at replacing bushes in the control arms/strut towers etc.
also, there's this greasy shit that goes between caliper pistons and brake pads (or anti-rattle shim) that supposed to help stop brake squeal.
when does it squeal?: hard turning, braking, let off brakes, hit bumps, lazy turning, low or high speed turns?
[Updated on: Sun, 18 January 2004 13:43]
boudan
Re: ma61 bugs Sun, 18 January 2004 13:48 Go to previous messageGo to next message
After a short drive the sqeaul become less apparent yet, not altogether.
There is squeal on brake pressure / and release, also low speed steering (parking).
Re: ma61 bugs Sun, 18 January 2004 13:55 Go to previous messageGo to next message
the squeal could also be 2 separate problems.
I'd grease it up again, and check your anti-sqeal shims are there.
if they're not, I have a spare set I scavanged off my wreck for just this sort of occasion.
Re: ma61 bugs Sun, 18 January 2004 14:16 Go to previous message
sounds weird - but maybe the calipers are not fully retracting when you take foot off pedal so pads are always scraping on the disk. squeal could be coming from the pads scraping or excess dust+shit from the pads touching the disks?
front wheel bearings? (tho U shoul hear them failing when cornering)
general dust + shit on front disks? - give wheels/disk/caliper a thorough wash/spray with high pressure water (then do the brake anti-squeal grease thing)
i have to do this to my rear brakes regularly as the dust+shit seems to build up on a low spot on the drum and eventualy, it sounds like a failing wheel bearing, but after a quick bath, the sound goes - i know its the drum/axle plate not being 100% but while the rear wheel bearings are OK i'll ignore it (when i does i'll have to buy cool1's diff with disks Wink )
charles.
Previous Topic:Apex'i S-AFC and 7M-GE AFM ??
Next Topic:3SGTE -> 3SGE??????
Current Time: Sun Oct 18 02:28:36 UTC 2026
Total time taken to generate the page: 0.0053470134735107 seconds
