Toymods » Tech & Conversions » advantages of apexi S -AFC?
Chris Davey
sunny coast, qld
advantages of apexi S -AFC? Mon, 19 January 2004 02:49 Go to next message
1jz running 14psi, with aftermarket intercooler, 3" exhaust, twin dumps and cold air induction, stock injectors but bigger fuel pump. Is there any need to get a S-AFC to tune the air/fuel ratio or would it be alright running stock computer?
Does anyone know if the S-AFC has any boost cut or speed cut capabilities?
Chris
Soarer
Wollongong
Re: advantages of apexi S -AFC? Mon, 19 January 2004 04:47 Go to previous messageGo to next message
The Toyota 1JZ ECU runs obscenely rich at high rpms (mine dips down into the 9:1 air/fuel ratio). A SAFC will help a lot, not only for better fuel economy, but bringing the ratios back to around 12.5:1 will increase power a lot also.
The SAFC does not have any boost or speed cut defenders built in.
Celia-Sue
Re: advantages of apexi S -AFC? Mon, 19 January 2004 05:19 Go to previous messageGo to next message
Nor does it allow you to alter timing - which some of the high-end interceptors do (eg Emanage). Still, it is a cheap way to get some extra power (leaning out mixtures), especially if you have no intention of going aftermarket ECU at a later date.
Justin
JZA61
Chris Davey
sunny coast, qld
Re: advantages of apexi S -AFC? Mon, 19 January 2004 05:28 Go to previous messageGo to next message
that is the question! DOn't know how far i want to go?
anyone used NO2 on a 1jz with stock turbos? would definitely get ECU for that. do you need extra fuelling? does it affect the turbos eg. turbos are running 14psi pretty well then you put 50hp NO2 in. Possible illeffects to turbos or just harder on engine internals?
[Updated on: Mon, 19 January 2004 05:31]
Soarer
Wollongong
Re: advantages of apexi S -AFC? Mon, 19 January 2004 06:26 Go to previous messageGo to next message
Using NO2 on a 1JZ with stock turbos is "bad thing". The ceramic turbines will not hold up to the task and you'll be shopping for new ones quicker than it takes you do a 1/4 mile run Sad
I've heard that running nitrous is equivalent to doubling boost pressure, and I know the factory turbos won't hold up to 28psi.
Chris Davey
sunny coast, qld
Re: advantages of apexi S -AFC? Mon, 19 January 2004 06:27 Go to previous messageGo to next message
thanks mate.
Re: advantages of apexi S -AFC? Mon, 19 January 2004 06:32 Go to previous messageGo to next message
the problem is actually that the stock wastegates are crappy and small.
if you want to put nitrous thru it, you'll need a nice big external wastegate, which means you might as well get a nice big aftermarket turbo or 2
Chris Davey
sunny coast, qld
Re: advantages of apexi S -AFC? Thu, 29 April 2004 02:08 Go to previous messageGo to next message
Is the tuning of the S-AFC limited to the scope of the MAP sensor?
Ie. you have a FCD that tells the MAP sensor that you are running 14.7psi, you are actually running 17psi. Can you tune the S-AFC up to 17psi? (hypothetical question)
Chris Davey
sunny coast, qld
Re: advantages of apexi S -AFC? Thu, 29 April 2004 10:30 Go to previous messageGo to next message
Chris Davey wrote on Thu, 29 April 2004 12:08
anyone?
sideshow
Re: advantages of apexi S -AFC? Thu, 29 April 2004 10:46 Go to previous messageGo to next message
what is price of safc
if yr gettin close to 800 or 1000 bucks fitted
u mihgt aswell go for aftermarket ecu
u should be able to get a microtech supplied fitted and tuned for around 1800
safc are good idea but i think they are expensive for what they do when u compare them to an aftermarket ecu
i think its best to save abit more and get a full programable ecu
Chris Davey
sunny coast, qld
Re: advantages of apexi S -AFC? Thu, 29 April 2004 12:51 Go to previous messageGo to next message
i have found them for around $450 new.
I have a friend who can install it.
I got some prices for a new ECU and it was about $1900 for an ECU without installation or tuning.
what model microtech are you talking about? I thought the LTX12 was the go for the 1jz and they aren't real cheap Smile
sideshow
Re: advantages of apexi S -AFC? Thu, 29 April 2004 12:54 Go to previous messageGo to next message
oh yer sorry forgot u need lt12 microtech for 1j
450 new seems good
theyre very easy to wire up
Looonie
Auckland, NZ
Re: advantages of apexi S -AFC? Tue, 04 May 2004 08:22 Go to previous messageGo to next message
Are there specific S-AFC's for different models/engines, or a one size fits all custom wire in type thing? I thinking about buying one second hand to stop the filthy black shit all over the back end of my Soarer now that I've slightly boosted my 1G... Smile
sideshow
Re: advantages of apexi S -AFC? Tue, 04 May 2004 08:38 Go to previous messageGo to next message
yes there is diff ones
some airflows go form 1 to 5 volts
others from 5 to 1 volts as u accelerate
mx83toy
Re: advantages of apexi S -AFC? Tue, 04 May 2004 09:10 Go to previous message
i use one in my 1J and it works very well...along with leaning out the mixtures it kinda acts as a FCD don't ask how...something to do with the maps...i've taken mine to 1.2 bar im told you can go more but well i've got stocky turbos...
i'm taking mine out as i'm going for more power so yeah...its for sale in the for sale section
if you install one let me know i'll give you some pointer's
Previous Topic:RAJAY 302b turbo ?????
Next Topic:extractors or CAI?!
Current Time: Fri Oct 16 13:05:49 UTC 2026
Total time taken to generate the page: 0.0069210529327393 seconds
