Classifieds » Miscellaneous » AE86 coilovers + rear springs for sale
MrMcGuffin
AE86 coilovers + rear springs for sale Mon, 19 January 2004 03:22 Go to next message
I have some front coilovers and rear springs for sale.
They are quite firm though so I wouldn't recommend them for the road. Quite good for track.
I had them on the car for a while... cornering was really really flat and nice, but it was just too bumpy and skitish on Sydney roads.
I don't know much about them because they came with the car but the rear springs are 560lbs.
Pics are here...(Includes pics of how low the car is with them on)
http://www.geocities.com/mrmacguffin/Suspension/fo rsale.html
btw. the pics are quite large to get detail.
To be honest I don't really know what they are worth, but please no offers like $1,$10,$100...etc...
contact me on 0416 070 409 or email mrmcguffin@hotmail.com
Thanks.
Simon.
[Updated on: Mon, 19 January 2004 03:26]
IRA11Y
Club Member
Re: AE86 coilovers + rear springs for sale Mon, 19 January 2004 05:35 Go to previous messageGo to next message
I seriously doubt the rear springs are 560Lb considering even a very stiff front spring would be 400Lb
maybe you should take some measurements and work out the exact rate with an online calculator
Edit: and just to add, if the rears are 560Lb that would make the fronts 850Lb if it was set up with the correct front to rear ratio.... not even the V8 supercars run that high a rate, and it would make a 1000Kg car virtually undriveable
[Updated on: Mon, 19 January 2004 08:26]
slydar
Re: AE86 coilovers + rear springs for sale Mon, 19 January 2004 06:27 Go to previous messageGo to next message
need some more imfo. you know what insert is in the strut? are they stock sprinter struts bodys? how much are they shortened? are the inserts (dampners) ajustable? even if you could just take a measurement from say the bottom of the strut body to the top, where the threads end, thatd help. be definately good to know what brakes were on there.
IRA11Y
Club Member
Re: AE86 coilovers + rear springs for sale Mon, 19 January 2004 08:27 Go to previous messageGo to next message
free bump ... waiting for accurate info
MrMcGuffin
Re: AE86 coilovers + rear springs for sale Tue, 20 January 2004 05:58 Go to previous messageGo to next message
IRa11y Can you point me in the direction of a web site to calculate the spring rates?
I was just reading what was marked on the rear spring.
The struts are ae86 I think. When I put them on the car and took them off, I just swapped the front hubs over and they were standard AE86 brakes.
Not sure what insert is in them but they are adjustable a bit like Koni's where you can turn a flat tip at the top to make it more or less firm.
I took some measurements.
the rear springs are 29cm high.
From the bottom of the strut to:
bottom of thread is 32cm
top of thread is 43cm
top of coilover is 63cm
Hope it helps a bit.
I will try to find out more info, but as I said, they came with the car.
IRA11Y
Club Member
Re: AE86 coilovers + rear springs for sale Tue, 20 January 2004 06:37 Go to previous message
http://www.racingpc.com/tips/coils-springs.htm
make sure you measure uncompressed spring
Previous Topic:TA22, DYNA, CORONA, DAIHATSU PARTS
Next Topic:3SGTE FS
Current Time: Sun Oct 25 09:01:15 UTC 2026
Total time taken to generate the page: 0.059514999389648 seconds
