Toymods » Tech & Conversions » Gtech question.
DiZ_
The Eastwood MASSIVE !
Gtech question. Mon, 19 January 2004 07:58 Go to next message
With a gtech on a " estimated horsepower " run , wouldn't it make more sense to start the run , baby the car up to 4th gear and then hold it to the floor till you red lined 4th?
I was just thinking this because the manual says to run through all the gears , but on a dyno we use 4th gear to get close to a 1:1 ratio.
Re: Gtech question. Tue, 20 January 2004 02:21 Go to previous messageGo to next message
i would guess that you have to start from standstill, otherwise it doens't know how fast you are going, since it calculates speed from time and acceleration.
DiZ_
Re: Gtech question. Tue, 20 January 2004 03:47 Go to previous messageGo to next message
Thats not what I asked in my post.
Ofcourse the gtech needs to be started while stationary , I wanted to know that if starting the gtech , then going slowly through the gears till you got to 4th gear and then floored it to get a more accurate top reading then hammereing through all the gears.
Chris Davey
sunny coast, qld
Re: Gtech question. Tue, 20 January 2004 03:58 Go to previous messageGo to next message
personally, i would do what the instructions say.
FKN16V
NSW, East Coast
Re: Gtech question. Tue, 20 January 2004 04:03 Go to previous messageGo to next message
Theres a website with all this info shit on it.
http://www.gtechpro.com/gtechprocomp_howitworks.ht ml
I believe it has something to do with the way it measures, using slices of silicon vs g-force or something like that.
Im not sure if it'll answer your question but maybe give an understanding of who it works.
Steve
Re: Gtech question. Tue, 20 January 2004 04:49 Go to previous messageGo to next message
It measures rwhp buy using a formula
For instance
A 1500kg car with a 1/4 mile of 14.2 sec and a terminal speed of 130mph, would need to have 195rwhp to make this possible
If you get what I am trying to say
Re: Gtech question. Tue, 20 January 2004 04:54 Go to previous messageGo to next message
my understanding is that the original one calculates the HP from the estimated 1/4 mile time.
i would not be confident that the G-tech is sensitive enough to measure the acceleration properly while you are babying it thru the gears... the calibration of the G-tech (original one) is such that when it is measuring 1G (ie tilted), it reads between 0.96 and 1.04G, os it aint that crash hot..
if you are really concerned, take the damn thing for a run, and check yourself...
do a standing start, and then do a 4th gear start..
also remember that it gives a HP that doesn't really mean anything... it doesn't give you a graph (maybe the comp one does)
so the actual number is mor elike a 'mean hp' figure, which is what is usually calculated from 1/4 mile runs....
or you could ask on the G-tech forum on their site.. surely that would have been a better place to ask than here?
ed_ma61
Lost in the K hole
Re: Gtech question. Tue, 20 January 2004 05:24 Go to previous messageGo to next message
ok...
i 'get the question'...
theoretically your engine should make 'x' amount of power at 'y' rpm point in whatever gear youre in.
this power (regardless of gearing) will produce 'z' acceleration of a car of a given weight (which you enter).
it doesnt matter what gear youre in as the gtech will calculate the change in accel in time (which will be high in low gears, and low in tall gears)... but its all very simple maths to work out.
(this is in contrast to rollers on a chasis dyno, that take a direct measurement off the wheels, and require a 1:1 ratio through the box to see what is happening at the engine)
HOWEVER: errors are what will distort you readings...
... in low gears you have a very small time scale in which to recard changes in accel. which can make the fidelity of data a bit rough
... in tall gears, the accuracy is improved as the time scale is lengthened, however, rate of accel decreases, and changes may be harder to quantify
... plus in taller gears, youre going faster, and losing more and more power to wind resistance
compromise, do a 2nd gear run to redline. that way you have about 10secs of recording, the rate of change of accel is decent, plus terminal speed wont go much over 100kmh, so drag wont kick you in the ass to much
DiZ_
Re: Gtech question. Tue, 20 January 2004 05:32 Go to previous message
Most relavent post prize goes to ed
And the most irrelavent post prize goes to FKN16V
I guess tonight will see the real answer.
[Updated on: Tue, 20 January 2004 05:33]
Previous Topic:1JZ aftermarket turbo info please ...
Next Topic:o2 to pyro converter and runninin 1jz without o2
Current Time: Sat Oct 24 16:08:28 UTC 2026
Total time taken to generate the page: 0.0045559406280518 seconds
