Toymods » Tech & Conversions » 2t 3t hybrid pistons
ta2272
2t 3t hybrid pistons Tue, 20 January 2004 03:15 Go to next message
hey im am going to do the hybrid conversion and i was just wondering if there was any way you can use the 2tg pistons on the 3t rods, because the pistons are already fly cut and high compresion.
jason
SeptemberSquallIndustries
Re: 2t 3t hybrid pistons Fri, 23 January 2004 11:22 Go to previous message
No, you can't. The extra 8mm throw of the 3T crank is accommodated by a wrist pin height adjustment for 3T pistons compared with earlier 2T pistons. As all the rods are the same length 2T pistons with 3T crank will extend beyond deck height at TDC.
You could use 3T-C pistons with 2T crank though, although your resulting compression will be about 4ish:1.. =/ and 3T-G pistons lower again. Be great if you want to run 30PSI all day long though.
3T-C pistons on 78mm bottom end with 2T-G head often yields around 10.5:1, I believe. How much compression would you like to run?
Previous Topic:Conversion for my Luxy
Next Topic:fitting a CT26 to my 3T GTEU
Current Time: Fri Nov 20 20:36:02 UTC 2026
Total time taken to generate the page: 0.0055198669433594 seconds
