Toymods » Tech & Conversions » Electrical Speedo/Tacho -> Mechanical
ae864eva
Australia- Sydney
Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 05:09 Go to next message
Okay all the guru out there
just say i want to keep the original AE86 dash. But the engine im implanting in use electrical signal for both the speedo and tacho. Is there like a converter that i can use......cause i really don't want to change it to a digital dash...i personally think it kinda gay... Very Happy
CrAiGzEE
south of the big smoke
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 05:23 Go to previous messageGo to next message
need more information, what is the halfcut? the speed signal is sent from the gearbow, u need to pull the sender out and put the mechanical one in from your old box, this isnt very difficult at all
IRA11Y
Club Member
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 07:15 Go to previous messageGo to next message
ive just been researching this, you can buy a VDO elec speedo for around $250 (300Kmh 10cm face) which is self calibrating and you can use multiple input sequences for various diff and wheel diameter configurations when you chop and change around.
speedo is traditional face not 7 seg display as well.
Celia-Sue
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 07:26 Go to previous messageGo to next message
Oz_Craig wrote on Tue, 20 January 2004 16:23
Sounds good. But wouldn't the ECU be looking for an electronic speed signal from the gearbox and be unhappy?
Justin
JZA61
IRA11Y
Club Member
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 07:37 Go to previous messageGo to next message
you can buy a sender for it or adapt one to suit like off a 1j or 2j boxok
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 07:47 Go to previous messageGo to next message
Or you could always keep the original speedo cable etc. and have a pulse generator fitted to the cable in order to keep the ECU happy. What engine are you using, does it require an accurate speedo signal (i.e. for auto trans control), or basically a 'vehicle is not moving' one for idle control etc.? Very Happy
Celia-Sue
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 08:04 Go to previous messageGo to next message
Sorry for the thread (partial) hijack, but this info is just too good to pass up on Smile
I'm puting a JZX90 Chaser and autobox into an '84 Supra. The Supra dash will want a mechanical signal from the box (I could fit a mech. sender off a W58 or similar), but the ECU will be wanting an electronic signal to control the autobox.
So is a pulse generator an electronic sender that could be hooked up in addition to the mech sender? If so, that sounds like the way to go for me. Where do I get one and how would I calibrate it?
Many thanks!
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 08:13 Go to previous messageGo to next message
Hit the yellow pages (or similiar!), and find a place that does speedo calibrations etc. These people also do exciting jobs like fitting taxi meters etc., therefore usually can find something that will satisfy what you want. Sorry to say, I can't suggest anyone in Sydney that does this kind of stuff Surprised
Celia-Sue
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 08:32 Go to previous messageGo to next message
Another option I've been thinking about is keeping the JZ electric sender in place and finding a way to translate this to a mech signal to work the dash.
As a last resort, I'll fit an RSM (and watch RWKW figures instead of the road Razz ) to take the electric signal. But that'd be kinda ugly hanging off the dash. And being an old digi dash (with inverted 'L' tacho) style, I can't easily replace the tacho with a neat electric swap Sad .
I called Guageworks (Melbourne?)a few months ago about this - but they couldn't do much without seeing it. And I'm in Perth. Sad Sad Sad
ae864eva
Australia- Sydney
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 13:00 Go to previous messageGo to next message
The conversion im doing is 3sge Altezza engine into AE86. I know Bill Sherwood did this conversion using the Altezza speedo. But i really want to keep the AE86 stock appearence as possible
Re: Electrical Speedo/Tacho -> Mechanical Tue, 20 January 2004 13:11 Go to previous messageGo to next message
Celia-Sue - why do you need to replace your tacho??? Use the old school bar graph one you've got!
Matt20v
Richmond NSW
Re: Electrical Speedo/Tacho -> Mechanical Wed, 21 January 2004 09:15 Go to previous message
hey i had that same problem i just left it all mechanical and then ran a new wire from my dash which has a speed sensor wire in it to my new ecu and it worked fine if you want more info pm me its the easiest way i found and cheapest... free
Previous Topic:4ac Ae86 owners-oil pressure readout
Next Topic:ta22 gt lenses
Current Time: Sat Oct 24 07:14:26 UTC 2026
Total time taken to generate the page: 0.0048191547393799 seconds
