Toymods » Tech & Conversions » HELP ON BRAKES
GEARS
VICTORIA
HELP ON BRAKES Tue, 20 January 2004 05:55 Go to next message
WANT TO NO IF THERE IS ANY BRAKE UPGRADES AVAIL
FOR OLDER CAROLLA AT THE MOMENT I AM RUNNING
CARONA FRONT BRAKES AND CARONA DIFF BUT WANT TO
LOOK AT PUTTING SOMETHING A LITTLE BIGGER ON
ANY SUGGESTIONS WOULD BE APPRECIATED
Grega
melbourne.victoria.austra...
Re: HELP ON BRAKES Tue, 20 January 2004 18:38 Go to previous messageGo to next message
bit more info here might help???
corona front brakes? which ones? xt130, rt132?
what struts are you running?
GEARS
VICTORIA
Re: HELP ON BRAKES Tue, 20 January 2004 20:21 Go to previous messageGo to next message
NOT SURE ALL I WAS TOLD IS THAT THEY ARE OFF AN
83 MODEL IF YOU HAVE ANU SUGGESTIONS ON PREFERD STRUTS
AND SO ON WOULD HELP I HAVE HEARD OF LAND CRUISER
CALIPERS FIT BUT NOT SURE OF THE MODEL
Grega
Re: HELP ON BRAKES Tue, 20 January 2004 20:25 Go to previous messageGo to next message
NO NEED TO SHOUT please
try here for a start dude.
http://forums.toymods.org.au/index.php?t=msg&t h=26807&start=0&rid=664&S=8d075a12d69f 6173d30d44092d5c2165
and yes LN130 hilux calipers do bolt up, you need a dba F272 rotor turned down to 266mm and the bolt holes in the hat drilled out to 13mm.
also speak with fook - he is putting XT130 struts and hilux calipers in his KE55.
[Updated on: Tue, 20 January 2004 20:25]
GEARS
VICTORIA
Re: HELP ON BRAKES Tue, 20 January 2004 23:30 Go to previous messageGo to next message
Sorry dodnt mean to yell when you say the rotors to be
turned down where exactly do you machine is it the rotor
or the hat that you do
Grega
Re: HELP ON BRAKES Tue, 20 January 2004 23:34 Go to previous messageGo to next message
thats better
Very Happy
the f272 rotor is 273mm in diameter, whereas when you bolt the hilux caliper to the xt130 strut, the stock xt130 rotor is only 266mm in diameter.
if you bolt the caliper on it will then foul on the f272 rotor.
so you machine it (in a lathe) down to 266mm same as the xt130 rotor and its all good.
i have also read about removing 1.2mm off the hat of the disc but don't know if its underside or topside this needs to occur. my plan is to use a washer to space the caliper out correctly (remembering the hat holds the rotor to the hub - i don't want to weaken that area)
if you're in VIC i can get you these rotors (supplied new) and machined down - let me know.
[Updated on: Tue, 20 January 2004 23:35]
GEARS
VICTORIA
Re: HELP ON BRAKES Wed, 21 January 2004 04:24 Go to previous messageGo to next message
Having trouble with the disc the guys dont know what they are off
would be interested in the ones you can get wouldnt mind
knowing what the discs are off for future reference myself Rolling Eyes
Grega
Re: HELP ON BRAKES Wed, 21 January 2004 04:30 Go to previous messageGo to next message
peugeot 505, 504 and 604 - ventilated only. there is also a non ventilated type which is thinner.
[Updated on: Wed, 21 January 2004 04:31]
GEARS
VICTORIA
Re: HELP ON BRAKES Thu, 22 January 2004 02:23 Go to previous messageGo to next message
Also could you tell me which of the hilux diffs
i would require for the rear conversion
Grega
Re: HELP ON BRAKES Thu, 22 January 2004 04:29 Go to previous messageGo to next message
i need to know the same thing
actually i'm prolly going to use a VN borgwarner diff
GEARS
VICTORIA
Re: HELP ON BRAKES Thu, 22 January 2004 05:08 Go to previous messageGo to next message
How would that work would you still use the
toyota axels or would you something else done Smile
Grega
Re: HELP ON BRAKES Thu, 22 January 2004 06:22 Go to previous messageGo to next message
shorten the bogwarmer diff to TA22 size, weld on ta22 mounts to diff housing, shorten the tailshaft, get a 4.11 ratio crownwheel/pinion set and away you go...
no need for anything toyota then with this conversion. also have to use the donor cars' handbrake cables to suit.
[Updated on: Thu, 22 January 2004 06:23]
GEARS
VICTORIA
Re: HELP ON BRAKES Thu, 22 January 2004 06:43 Go to previous message
So you still use your original axels do you
Previous Topic:tvis red top 4age owners please help
Next Topic:sprintah 13" rims on ma61 ??????
Current Time: Wed Oct 21 02:57:52 UTC 2026
Total time taken to generate the page: 0.0057370662689209 seconds
