Toymods » Tech & Conversions » Turbo/blow through carb
Turbo/blow through carb Tue, 20 January 2004 06:56 Go to next message
Hey all
I've got an upcoming project of turbo'ing an Alfa engine. The guy that owns it insists (much to my VIOLENT PROTEST!!!) on keeping the carbs - DCOE 40 Webers. I understand the basics, just wondering if anyone has got specific experience with making these mongrels work with boost? Thanks guys! Cool
Re: Turbo/blow through carb Tue, 20 January 2004 10:20 Go to previous messageGo to next message
you'll really want a carb made for turbo blow thru - otherwise you have to seal the bushes around the butterflys, fill the floats with foam to top them crushing, work out how to block off all the vents without confusing the crap out of the carbi, etc ...
can you get an EFI setup off a similar series motor?
or use designed-for-blow-thru carb - in an earlier thread, someone said the mazda made one?
or stick the webber infront of the turbo - means you can't really run an intercooler (imagine the results of a backfire) but at least the carbi's will work as designed and will run rich enough under boost.
or buy some new hardware from speedtechnology or similar who make TBs that fit DCOE manifolds.
do a static test for the owner, get a carbi full of fuel bolted to a table, attach air line to hose from your vacuum cleaner and then duct-tape one end to the carbi - turn on air and watch fuel spray everywhere, light petrol for show and suggest to owner that's what'll happen under the bonnet...
otherwise good luck ... Confused
Re: Turbo/blow through carb Tue, 20 January 2004 12:26 Go to previous messageGo to next message
Yeah, I understand the basics of it, and for now the carbs must stay... There's NO way I'm doing anything suck through, and the carbs are already there. There are factory EFI parts available, but I have to set up the carbs and convince him first that's all Evil or Very Mad Besides, I've always bagged out carbied turbos based on seeing OTHERS cars, I want to play with one myself so I can badmouth them with authority Shocked
Surely someone's done this!
Re: Turbo/blow through carb Tue, 20 January 2004 15:14 Go to previous messageGo to next message
how amenable to persuation is this fiat owner?
my car is a suck-thru turbo .. at the recent brisbane cruise there was another 18RC like mine - CD175 stromberg infront of the turbo - i've also seen a few with a single side-draft weber infront of the turbo.
you'll be consuming time trying to get the webbers running - they're designed to have atmospheric pressure on the outside, the float chamber vents, metering passages rely on differences between manifold vacuum and atmo-pressure,...
the easiest way to solve that is to put the entire carbi in a box that's fed the compressed air from the turbo
you'll also need a rising rate fuel pressure regulator (to squeeze the fuel thru to the carbi when it gets pressurised) and air-tight seals around any throttle/choke linkages.
you'll also need a blow-off valve for when you take foot right off accel after having foot flat to the floor - essential unless you want seals to fail on the air-tight box and the butterflys to remain flat.
having bagged this humble weber, a quick search for "turbo webber" and "turbo weber" found:
<http://forums.toymods.org.au/index.php?t=msg&g oto=49973&rid=2087&S=ab0976f3e90026787d3aa 47d93feb2cd>
and
<http://forums.toymods.org.au/index.php?t=msg&g oto=156637&rid=2087&S=ab0976f3e90026787d3a a47d93feb2cd>
and
<http://forums.toymods.org.au/index.php?t=msg&t h=9506&rid=2087&S=ab0976f3e90026787d3aa47d 93feb2cd&pl_view=&start=0#msg_76041>
and
<http://forums.toymods.org.au/index.php?t=msg&g oto=4567&rid=2087&S=ab0976f3e90026787d3aa4 7d93feb2cd>
plus this on the web seem relevant:
<http://datsun1200.com/modules/newbb/viewtopic.php? topic_id=6404&forum=1>
Re: Turbo/blow through carb Wed, 21 January 2004 11:41 Go to previous messageGo to next message
Well, suck through is not an option:
1. The turbo isn't suitable
2. It's gonna be intercooled
3. The ALFA (not fiat! hah!) already has twin sidedraft (40 DCOE) webers, and they're staying right where they are. Going to be making up a reasonable looking plenum, and I've already got the fuel system (pressure reg, pump, etc.) sorted - you don't need a rising rate reg, just a 'normal' one set to 6 psi above plenum pressure is fine! As far as I can see, all I need to do is pressurise the tube going to the float chamber, and also run a hose to the diaphragm on the bottom of the carb, then spend hours on the dyno with a box of jets trying to get the mongrel thing to run. Just looking to see if I've missed anything, and if any other poor fool(!) here has done this Very Happy
Re: Turbo/blow through carb Wed, 21 January 2004 14:00 Go to previous messageGo to next message
mrshin wrote on Wed, 21 January 2004 21:41
<snip>
fiat/alfa/schmalfa .. they're all landfill for olive tree groves.. Wink
seriously now...
accel enrichment (can't quite remember how the weber does this) may need serious work?
don't forget the blow-off valve?
timing? is the motor decompressed? if so then you'll need more advance than standard at idle, but less total mechanical advance (otherwise you'll detonate from excessive advance on boost) - you could try to find a vacuum advance unit from an older turbo dizzi that responds to both vacuum and boost.
if motor is at factory compression, you;'ll definately need some kind of boost retard - and probably a modified curve as factory mechanical and vacuum advance curves will result in pinging/detonation. plus see prev para about a dizzi.
water injection - helpful in controling pinging/detonation?
a fire extinguisher for when the gaskets in the webers give up from the pressure? Cool
allencr
tallahassee FL usOFa
Re: Turbo/blow through carb Wed, 21 January 2004 17:41 Go to previous messageGo to next message
Lotus did this(blow through) 20 years ago with one of theirs, and the factory/engineers said they would NEVER attempt it again.
Re: Turbo/blow through carb Thu, 22 January 2004 10:49 Go to previous messageGo to next message
We're changing the engine to a recent rebuild one, and it's only 9:1 compression. Going to give the dizzy a recurve, as well as fit it with a vac advance/pressure retard unit, and set it up on the dyno. Plus it's going to be intercooled, blow off valve, etc. - all the needed crap.
Italian cars landfill... Well, yeah I'm not exactly into them myself, although they DO have some good points, they're just buggers to work on...
I have heard of the Lotus effort, and I know they weren't brilliant - hell I'm not exactly big on this carb/turbo idea, but I'm at least willing to give it a go for the owner's sake. And the car already has an extinguisher Evil or Very Mad
Jayem
Finland
Re: Turbo/blow through carb Thu, 22 January 2004 11:10 Go to previous messageGo to next message
For some odd reason in Finland here are quite many cars going around with turbo/carb setups and I mean blow through setups. Propably some weird relic from the eighties.
http://wwnet.fi/users/tuomisto/3T-GT.jpg
But see if this helps:
http://www.geocities.com/jharkola/1380turbo4.html
Re: Turbo/blow through carb Thu, 22 January 2004 13:13 Go to previous messageGo to next message
Yup, that's the kind of setup I'm talking about. Also, I'm tending to get the idea that Dellorto carbs might be a better choice? IE better sealing around the throttles etc.? I have the option of using them instead of Webers, should I choose to. Anyone got much to say on this??? Twisted Evil
Re: Turbo/blow through carb Fri, 23 January 2004 01:00 Go to previous messageGo to next message
Modifying carbs for blow-through applications is a PITA. If it was me I'd be enclosing the carbs in a sealed box; much easier and neater!
alex_ta22
Newcastle, Hunter Valley
Re: Turbo/blow through carb Fri, 23 January 2004 02:07 Go to previous messageGo to next message
what alfa is this? 33, 75, gtv?
Re: Turbo/blow through carb Fri, 23 January 2004 06:57 Go to previous messageGo to next message
Alfetta with the 2.0l twin cam engine already sporting dellorto's Evil or Very Mad
alex_ta22
Re: Turbo/blow through carb Fri, 23 January 2004 13:10 Go to previous messageGo to next message
does anyone know if the webers on a flatfour alfa33 can be used as sid drafts? they are mounted like down drafts yet they have the dcoe pattern
Re: Turbo/blow through carb Fri, 23 January 2004 13:15 Go to previous messageGo to next message
They'd be IDA webers, yeah? In which case, no, they won't like working sideways! Just take a look at the float and think about how it's gonna work the wrong way up. Whats the plan, anyway?
gold28
Madrid - Spain
Re: Turbo/blow through carb Sat, 24 January 2004 09:05 Go to previous messageGo to next message
Many people in Europe remove efi and install webber/dellorto type carbies, namely because they dan't have the same aftermarket efi gear we have here. Think about it, try getting big power gains using only the standard ECU, no affordable aftermarkey computers and no Japanese interceptor type computers.
That doesn't mean that it is the better way to go. They use carbies because they work well on N/A engines without the technology that they can't get easily. For a forced induction car in Australia, your crazy not to use the technology available here.
There are plenty of efi throttle bodies available that will bolt up to the webber manifold and do the job better, more efficiently and possibly cheaper in the long run. I have seen a Valiant 265 engine with these T/B's on it. It ran absolutly huge cams in it, bigger than the R/T race engines, yet was easy to drive and had heaps more midrange power.
Jayem
Finland
Re: Turbo/blow through carb Sat, 24 January 2004 11:35 Go to previous messageGo to next message
So true! Crying or Very Sad
In Finland we have only one aftermarket computer maker and that's only maker in Europe that I know of, not saying that there aint others. Anyway, it's called Hestec and it's VERY good and popular in racing circles. It's also $$$$.
Here is also big markets for Dellortos and Webers, both European.
STR8 2.8
Re: Turbo/blow through carb Sat, 24 January 2004 12:18 Go to previous messageGo to next message
damn i love alfetta's, they are so sexy, even if 99.99% of them are 99.99% rust
Re: Turbo/blow through carb Sat, 24 January 2004 13:04 Go to previous messageGo to next message
Okay peoples, I KNOW that EFI is the way to go, believe me I've been jamming this down people's throats for years... Thing is, it just isn't an option in this case, and besides, I'm keen to try this blow through carb thing Evil or Very Mad Surely SOMEONE here has set one up at some stage and can share a few pointers...??
Alfetta's sexy? All a matter of personal opinion, really Very Happy
Re: Turbo/blow through carb Sun, 25 January 2004 13:10 Go to previous messageGo to next message
c'mon peoples...
Re: Turbo/blow through carb Sun, 25 January 2004 13:24 Go to previous messageGo to next message
Dude, I think if anyone knew anything they would have said something by now. Most people here are smart enough to use EFI!
gold28
Madrid - Spain
Re: Turbo/blow through carb Mon, 26 January 2004 10:31 Go to previous messageGo to next message
The only thing I can help you with is that Carbies are pretty sensative to fuel pressure and that boost pressure will quickly have the fuel going the wrong way through the jets.
I know there have been some successful turbo carby cars done,so it deffinitly aint impossible, It will take some work to get it right though.
Whats the guys objection with changing to efi??
Maybe it might be worth talking to Webber. Chances are they may have already solved most of your problems and can provide the required equipment.
Joshstix
Toymods Vice President
Re: Turbo/blow through carb Tue, 27 January 2004 04:12 Go to previous message
Lotus ran blow through Dellorto's with a water to air charge cooler in earlier Esprit's. They were sealed from the factory to suit boost so if you could find some of these I'd assume you'd be off to a good start.
Previous Topic:Speedo correction device
Next Topic:R154A in a MX83
Current Time: Wed Oct 28 06:22:25 UTC 2026
Total time taken to generate the page: 0.026159048080444 seconds
