Classifieds » Miscellaneous » Race prepared 3sge head
3sglevin
Race prepared 3sge head Wed, 21 January 2004 01:10 Go to next message
Race prepared 3sge Head, fully prepared and ported by Phil Ryal. Ivan Tighe billet cam shafts,with vernea adjustable cam wheels, shim under buckets(shimmed for cams), iskidarian double row valve springs, under cut valves, fully ported, custom inlet manifold and 20v throttles & trumpets. Fuel rail and injectors that where fully overhauled, with 2 spare.
All this was assembled and has only done a few 2 race meetings so in excellent condition
Attachment: 3sghead1.jpg
(Size: 45.88KB, Downloaded 194 time(s))
Attachment: 3sghead4.jpg
(Size: 48.19KB, Downloaded 149 time(s))
Attachment: 3sghead5.jpg
(Size: 70.74KB, Downloaded 133 time(s))
[Updated on: Wed, 21 January 2004 01:17]
ed_ma61
Lost in the K hole
Re: Race prepared 3sge head Wed, 21 January 2004 01:43 Go to previous messageGo to next message
*squirt*
Shocked Shocked Shocked
hehehe, how long did it take phil to do all that for you !! lol
cam specs?
OS valves?
stock injectors (gen3?)?
ballpark figure?
3sglevin
Re: Race prepared usage head Wed, 21 January 2004 02:16 Go to previous messageGo to next message
Hi ed_ma61,
they say learning Patience builds character.......... If that is the case how much Patience I have is unmeasurable Laughing Although he builds good stuff Evil or Very Mad
Cam specs are square (inlet/exhaust the same) 50thou of lift @ 230deg with 422 thou of max lift
Standard valves, but undercut to increase flow (this also comes with a big port head with valves & std springs)
The Injectors are Nissan off a 2.5l single turbo engine but over hauled.
Billet cams around $1500.00
vavle springs $450.00
undercutting valves $250.00
shim under bucket conv $600.00
Porting the head $1200.00
manifold $800.00
trumpets $250.00
assembly and shimming ???
this is what it cost me, plus the injectors and overhauling.
Dollars I want about $2,200.00
[Updated on: Wed, 21 January 2004 23:47]
levinracer
Re: Race prepared usage head Fri, 23 January 2004 01:43 Go to previous messageGo to next message
CHEAP CHEAP CHEAP.....WHAT A BARGAIN!!!
slydar
Re: Race prepared usage head Fri, 23 January 2004 02:03 Go to previous messageGo to next message
i wonder if i could some how fit this to a 4ag? bit of metal putty and some tec screws should do it. maybe bill sherwood would be interested. you should post it up on the aussie clubmans forum too.
no_tofu_speed
Jab what?!!?!
Re: Race prepared 3sge head Fri, 23 January 2004 02:40 Go to previous messageGo to next message
I am a amateur with tuning knowledge, so please have a bit of patience with such questions but.......
Which version 3s head is it off?
The kinda of tuning done would give a nice jump in not just the HP/KW but specifically torque as well right?
Can you tell me an estimate of what the figure changes may be?
And could you use such a head with a 3sgte bottom end and used forced induction or would that just defeat the purpose?
levinracer
Re: Race prepared 3sge head Fri, 23 January 2004 05:28 Go to previous messageGo to next message
hey tofu, this head is perfect for a turbo motor,the cams are an ideal size...you should snap it up.....its.....CHEAP CHEAP CHEAP!
Brad Shocked Shocked Shocked
domasik
Re: Race prepared 3sge head Sun, 25 January 2004 01:33 Go to previous messageGo to next message
wat kinda of output are we talking here??
3sglevin
Re: Race prepared 3sge head Fri, 30 January 2004 08:52 Go to previous message
Sorry been away, it made 160hp at the wheels on my bottom end and on a dyno dynamics dyno!
Previous Topic:i/c micks metal
Next Topic:3SGTE performance parts
Current Time: Tue Oct 13 04:05:37 UTC 2026
Total time taken to generate the page: 0.0056688785552979 seconds
