Toymods » Tech & Conversions » Widest tyres on Back of TA22
13BTA22
Widest tyres on Back of TA22 Wed, 21 January 2004 02:54 Go to next message
I just bought a set on B45 15 inch and wondering the widest tyres I could fit on them.The guards are rolled.I tried on the search but could not find the truth. Sad
T APLUS 22
Re: Widest tyres on Back of TA22 Wed, 21 January 2004 06:48 Go to previous messageGo to next message
well to keep the speedo accurate you would need either 215/225/50/15. But I think those two are the minimum you can put on a 7" without looking too thin. So you can go much higher. I would think 235 won't be too much of a problem.
Hang on, isn't yours tubbed? I'd be going as wide as I could, you'd have enough room wouldn't you?
bman
melbourne
Re: Widest tyres on Back of TA22 Wed, 21 January 2004 07:59 Go to previous messageGo to next message
iv'e been told no more than 8 inch, providing correct offset, shortened diff and rolled guards!
otherwise i'd say 7 - 7.5 inch max.
Lachie
Re: Widest tyres on Back of TA22 Thu, 22 January 2004 02:01 Go to previous messageGo to next message
I saw this thread once before on these forums and I think the consesus was that 225's are the widest you can go.
Depends on the year of the car as well, I think I believe the early model celicas had narrower (closer together) body rails. Then they changed to the wider body (RA23 style, wider guards) before they moved the body rails out.
If you have a celica with narrow body rails and the wider body/guards, then I think you can go bigger then 225's.
Correct me if I'm worng anyone, it's just something that I remember reading somewhere and have no idea about how accurate it is.
Lachie
Necros
Re: Widest tyres on Back of TA22 Thu, 22 January 2004 06:30 Go to previous messageGo to next message
Well I had 225's on MA61 supra mags (not sure if they were 15's or 14's though) on my RA23... The susp was std but they fit no worries....
I think with the right offset and rolled guards that 245's could probably fit.... The easiest way to work it out is to take the car + rims to a tyre shop and try different sizes!
Re: Widest tyres on Back of TA22 Thu, 22 January 2004 08:23 Go to previous messageGo to next message
That might fit on an RA23, but TA22's have significantly less room back there.
silvercil40
Re: Widest tyres on Back of TA22 Fri, 23 January 2004 13:48 Go to previous message
Check with a tyre dealer, there is a way of measuring it but im not too sure how its done.
I saw it in a mag wheel catalogue. Maybe dragway catalogue?
[Updated on: Fri, 23 January 2004 13:49]
Previous Topic:What tyres to use for 13" rim?
Next Topic:Conversion for my Luxy
Current Time: Fri Nov 20 20:22:03 UTC 2026
Total time taken to generate the page: 0.0056750774383545 seconds
