Toymods » Tech & Conversions » GZ20 Brake Problem PLEASE HELP
soaringmik
GZ20 Brake Problem PLEASE HELP Wed, 21 January 2004 04:22 Go to next message
I have had a shuddering problem with my brakes for quite a while, and I recently replaced my front rotors the shuddering stopped for about 1 day and then it started again and the shuddering is just as bad as before, if not worse.
Has anyone else had this problem or know of it?, What could it be?, How do I fix it? it drives me insane Mad
[Updated on: Wed, 21 January 2004 04:48]
Re: GZ20 Brake Problem PLEASE HELP Wed, 21 January 2004 05:04 Go to previous messageGo to next message
calipers?
Dabbid
Yowie Bay, Sydney
Re: GZ20 Brake Problem PLEASE HELP Wed, 21 January 2004 11:06 Go to previous messageGo to next message
checked ya wheel bearings??
Chris Davey
sunny coast, qld
Re: GZ20 Brake Problem PLEASE HELP Wed, 21 January 2004 12:03 Go to previous messageGo to next message
don't know the solution but my old gz20 used to do that to but only slowing from high speeds. sorry, but i just lived with it.
allencr
tallahassee FL usOFa
Re: GZ20 Brake Problem PLEASE HELP Wed, 21 January 2004 17:35 Go to previous messageGo to next message
shuddering - the brake pedal pulses and the steering wheel shakes?
i think that the hub surface that your rotor mounts on isn't flat & smooth. most disks have an extra hole or two for setup/indexing when manufactured or just for the hell of it, and these holes leave a little raised nipple of rust/corrosion on the mating surface of the hub. putting the disk on with that "bump" not in a corresponding hole forces the disk to bend when heated.
soaringmik
Re: GZ20 Brake Problem PLEASE HELP Thu, 22 January 2004 04:48 Go to previous message
Thanks allencr, that sounds about right, I spent $700 on new rotors about 1 month ago, do you think I have permanently damaged them?, or can I just get them machined a little?
Previous Topic:Stock 97' rolla conversion to turbo....
Next Topic:Hilux 4WD brake prop valve location ?
Current Time: Sun Oct 18 01:35:49 UTC 2026
Total time taken to generate the page: 0.057451963424683 seconds
