Toymods » Tech & Conversions » tvis red top 4age owners please help
MR PLOW
neverland
tvis red top 4age owners please help Wed, 21 January 2004 09:19 Go to next message
we just put in a red top tvis out of the ae82 into an ae71 and used everything from the rolla and it will idle and everythings fine but it will not rev(ie if i snap or slowly open the accelerator it will die)(leaning out).
the injectors have been done so that rules them out.
im thinking it has to be fuel but dont want to start changing things for no reason.
anyone had this problem
brad
IRA11Y
Club Member
Re: tvis red top 4age owners please help Wed, 21 January 2004 10:34 Go to previous messageGo to next message
check the injector earth on the plenium
MR PLOW
neverland
Re: tvis red top 4age owners please help Wed, 21 January 2004 10:42 Go to previous messageGo to next message
yeah pretty sure i bolted that down but will triple check tomorrow why would it only stop it from reving though and not idling
Scorpion
Menai area of Sydney
Re: tvis red top 4age owners please help Wed, 21 January 2004 10:53 Go to previous messageGo to next message
Hey Brad,
Sounds like you might be running on the cold start injector and the main ones aren't kicking in. Confused
MR PLOW
neverland
Re: tvis red top 4age owners please help Wed, 21 January 2004 11:00 Go to previous messageGo to next message
hehe not anymore the line got a tiny split in it so i gotta get on made up or go to the wreckers and get one.
you know the funny thing i un plugged it and nothing changed i thought hey may as well try it and see
Grega
melbourne.victoria.austra...
Re: tvis red top 4age owners please help Wed, 21 January 2004 19:10 Go to previous messageGo to next message
check your map sensor is plugged in...?
pannelvan_screema
Campbelltown, NSW
Re: tvis red top 4age owners please help Thu, 22 January 2004 01:01 Go to previous messageGo to next message
What fuel pump are u running??
I have done the same conversion and diddnt have a prob
I used a VL pump.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: tvis red top 4age owners please help Thu, 22 January 2004 01:15 Go to previous messageGo to next message
Grega wrote on Thu, 22 January 2004 05:10
my money's on this. Had a similar prob when the line came off, engine doesnt want to rewv at all
MR PLOW
neverland
Re: tvis red top 4age owners please help Thu, 22 January 2004 08:32 Go to previous messageGo to next message
k well now after getting the shits at work all day i found a vaccum leak plugged that up and now it doesn't idle unless i hold the throttle open a bit and wind the idle screw right out the map and tps are both working and plugged in.
hmmmmm
matches are gettng closer hehe
Scorpion
Re: tvis red top 4age owners please help Thu, 22 January 2004 08:59 Go to previous messageGo to next message
If you look inside the mouth of the throttle body there is a hole on the bottom on the firewall side. That should be sucking heaps when cold and slowly shuts off as the engine warms up. It makes most of the sucking noise when you first start and if you block it off slowly with your finger the revs should slowly drop. Is yours sucking ? (so to speak Shocked )
feral4mr2
Bundaberg, Qld.
Re: tvis red top 4age owners please help Thu, 22 January 2004 09:07 Go to previous messageGo to next message
Freak have you checked to see if the ECU throws any codes?
MR PLOW
neverland
Re: tvis red top 4age owners please help Thu, 22 January 2004 11:31 Go to previous message
how do i check the codes
Previous Topic:Two Computers?
Next Topic:HELP ON BRAKES
Current Time: Tue Oct 20 22:56:24 UTC 2026
Total time taken to generate the page: 0.0052039623260498 seconds
