Toymods » Tech & Conversions » ULP filler
bmak
ULP filler Wed, 21 January 2004 13:03 Go to next message
Thinking about putting an ULP restrictor in my KE70.
Is there an easy conversion? if not i prob wont bother.
demuire
Ipswich
Re: ULP filler Wed, 21 January 2004 13:09 Go to previous messageGo to next message
I'm looking for one of these too (I have to run one) - haven't been able to find one anywhere!
bmak
Re: ULP filler Wed, 21 January 2004 13:31 Go to previous messageGo to next message
Ive been looking when im at the wreckers but havent found 1 that would be simple.
demuire
Ipswich
Re: ULP filler Wed, 21 January 2004 13:59 Go to previous messageGo to next message
I've heard that you can buy glue-in/weld-in ones, that's apparently what the import people use when compliancing import cars, but I haven't been able to find anywhere that actually sells them...
ra23celica
Re: ULP filler Thu, 22 January 2004 00:57 Go to previous messageGo to next message
Go to your wrecker and grab a post '86 ULP filler neck. AE82 Corolla or whatever, you can find one. Cut out the section with the flap door and the breather holes above it and have that welded into your original filler neck. I had this done for my RA23 using a GX61 filler neck.
Mitch.
ddeane
PNG
Re: ULP filler Thu, 22 January 2004 02:15 Go to previous messageGo to next message
Gidday
I purchased mine from a 'grey importer' cost the princely sum of $20. On the celica it was an interference fit.
I am also sure Autopro/bumper-to-bumper etc can supply.
'Spose the qustion is 'why do you want one'? You can no longer buy leaded fuel and I understand they are no longer a requirement by engineers for conversions.
Craig
demuire
Ipswich
Re: ULP filler Thu, 22 January 2004 05:04 Go to previous messageGo to next message
They are? My engineer told me to get one...
I might try AutoOne or something...
Re: ULP filler Thu, 22 January 2004 05:36 Go to previous messageGo to next message
if you're changing over to an engine that was desgined to run U/L in an EFI system with a cat, you're supposed to put the restrictor there - so in theory you can't put LRP into it and produce emissions above the designed limit of the engine... but seeing as so many of us are either:
-producing power way in excess of factory standard
-madly driving like a gorilla with it's arse on fire
its really a bit futile to try to stick to a 'designed' emissions standard... Wink
bmak
Re: ULP filler Thu, 22 January 2004 12:42 Go to previous messageGo to next message
Pulled the stuff of an AU tank tonite.
Doesnt look that hard to get to fit. I'll just cut it up a bit & tack weld it in my filler neck.
The i'll weld the outer piece on so i can use the late model cap.
ra23celica
Re: ULP filler Thu, 22 January 2004 23:31 Go to previous messageGo to next message
And there you have it - sounds like a plan !
Cool
Mitch.
bmak
Re: ULP filler Mon, 26 January 2004 07:19 Go to previous messageGo to next message
Did some work fitting the filler today.
Pretty easier & now all i have to do is weld it.
Sorry about the low quality pics but they were only done with my phone.
http://members.dodo.net.au/~bmak/res.jpg
This is the restrictor removed from the falcon inlet, only took a couple of taps to break the spot welds.
http://members.dodo.net.au/~bmak/res2.jpg
Here it is after i cut off the end of my standard filler. Its a perfect fit.
http://members.dodo.net.au/~bmak/res3.jpg
This is the end of the falcon filler. fits in perfectly once the fittings have been cut off.
All i have to do is weld it in now.
SPRINTAH!
Re: ULP filler Wed, 28 January 2004 03:21 Go to previous messageGo to next message
just be careful welding it...... it is a FUEL tank
bmak
Re: ULP filler Wed, 28 January 2004 09:38 Go to previous messageGo to next message
It was removed from the tank when i welded it.
Ive tig welded a few fuel tanks before, if your smart you wont blow yourself up.
hemi twofifteen turbo
Re: ULP filler Thu, 29 January 2004 07:48 Go to previous message
i just bought a celica and it was unleaded 18rg
i thought it was factoy? car is 77 model, and has the flap.
car also has a cat.
or was i just lucky?
Previous Topic:!#$^#! water pump!
Next Topic:Wiring a 1ggte into a ra23
Current Time: Fri Nov 20 13:34:49 UTC 2026
Total time taken to generate the page: 0.0069539546966553 seconds
