Toymods » Tech & Conversions » Damm Aircon!
SW20R
Damm Aircon! Thu, 22 January 2004 06:50 Go to next message
Ok guys im buggered as to why my aircon doesnt work..
Checked the passengers side kick panel for fuse - Fine
All fuses Fine.
Reloaded the system with some r12 gas to a good pressure
When pressing the Aircon switch on the dash. the revs drop then increase so the compressor IS kicking? but is not getting colder?
auto electrician reckons the compressors broke. but it does kick just not getting cold?
would my best bet be just to replace the compressor and try all over again?
[Updated on: Thu, 22 January 2004 06:51]
jasonp1977
Re: Damm Aircon! Thu, 22 January 2004 06:59 Go to previous messageGo to next message
does the AE82 have a dual pressure switch in the lines like the ae92?
SW20R
Re: Damm Aircon! Thu, 22 January 2004 07:21 Go to previous messageGo to next message
it should have.. i have an ae92
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Damm Aircon! Thu, 22 January 2004 07:45 Go to previous messageGo to next message
is the condensor blocked? is it getting air flow? check the pipe form the compressor to the condensor
MR PLOW
neverland
Re: Damm Aircon! Thu, 22 January 2004 08:26 Go to previous messageGo to next message
mick do you have enough gas in the system mate cause if its cutting in and out then thats a good start i think you should just get it retrofitted around $200 and then its got 134a gas in itas they dont make r 12 any more only suck it out of wrecks.
brad
dingaling
tas
Re: Damm Aircon! Thu, 22 January 2004 10:35 Go to previous messageGo to next message
my supra air con don't work either, it was made for r12, but has since had that new 134a gas put in, and has cuased it to leak.
what should i do? get a new compressor that is made to work with 134a? or would redoing all the rubber seals in my current compressor be a better idea? i hear putting 134a gas into a r12 compressor kills the rubber seals in no time.
MR PLOW
neverland
Re: Damm Aircon! Thu, 22 January 2004 11:38 Go to previous messageGo to next message
um did you get an a/c person to retro fit the a/c if they did it properly it shouldnt hurt the seals.
y did you get it done in the first place probably leaked b4 that.
you know you should run your a/c for 5-10mins once a week, that may be why it leaked as the seals dont get lubricated so they dry up then you go to use it at the start of summer and the seals blow out.
brad
dingaling
tas
Re: Damm Aircon! Thu, 22 January 2004 13:32 Go to previous message
yeah was leaking before i got the car, there was a sticker under the bonnet saying it was filled with 134a gas, and so i'm assuming it wasn't done right as it leaks.
fixing leaky aircons is expensive right? and probably above what a DIY person such as myself could manage? any advice?
Previous Topic:lukey mufflers.. exhaust people help.
Next Topic:Two Computers?
Current Time: Thu Oct 22 16:49:42 UTC 2026
Total time taken to generate the page: 0.036278009414673 seconds
