Toymods » Tech & Conversions » fitting a CT26 to my 3T GTEU
turbo wagon
adelaide
icon5.gif  fitting a CT26 to my 3T GTEU Thu, 22 January 2004 08:24 Go to next message
i need help my turbo is blowing a shit load of smoke when changing gears. I am wishing to replace it with a Ct26 from the 3L soarer. what would be involved in it. will i need to have an intercooler. Would the lag be much worse then the CT20. what would the estimated power out put be if i was to run stock boost and stock everything else(eg,internals,injectors,so on and so on. how much bigger is the CT26 then the CT 20.
Re: fitting a CT26 to my 3T GTEU Thu, 22 January 2004 09:22 Go to previous messageGo to next message
I've got a custom manifold for sale Smile its on the for sale forums.
This will hold the CT20-B. I find get around 20psi of boost at 4000rpm or so. Starts making boost around 2500 maybe even lower.
The CT20-B is no laggier than the stock CT20 really. In physical size though they are heaps bigger!
turbo wagon
adelaide
Re: fitting a CT26 to my 3T GTEU Thu, 22 January 2004 11:53 Go to previous messageGo to next message
are you from adelaide. how much are they and how easy r they to get. what other things will i have to do to put the turbo on to your manifold. how much higher does it sit the the stock ct20 :?what turbos are the 1jz turbos. will they fit. will i have to extend the oil lines and other shit.i dont really know what to do. Sad
CLG
Perth, Western Australia
Re: fitting a CT26 to my 3T GTEU Thu, 22 January 2004 13:40 Go to previous messageGo to next message
Do you have your crankcase ventilated? AS 3TGTE's get older, they start to breathe which is characterised by oil smoke on lift off. Make sure your rocker cover outlet is not blocked and open to the inlet air pipe or atmosphere (filter if so).
To fit a CT26 to your manifold, you'd have to have an adapter plate welded to your manifold, and fluid lines modified to accept the new turbo. You could also choose to use an aftermarket manifold like the one above. you'll need to consider an intercooler if you wish to raise the boost, but not necessary for under 10psi boost levels. lag would depend on the type of CT26 you get, everyone will be different, but remember, they are designed for bigger motors, but having said that, the original CT20 isn't going to show much difference!!! Power output with a CT26 would be around 175BHPish, given everything else is stock
ta23
Re: fitting a CT26 to my 3T GTEU Thu, 22 January 2004 15:03 Go to previous messageGo to next message
Apparently you dont need an adapter plate to fit the 7MGTE CT26 turbo you just need to bore out the original manifold holes a little.
TE72_Turbo
Re: fitting a CT26 to my 3T GTEU Fri, 23 January 2004 11:01 Go to previous message
Correct, except its the exhaust housing holes that you need to elongate. Its been covered extensively on this forum a few times.
Previous Topic:2t 3t hybrid pistons
Next Topic:3K and 4K head differences, need to know
Current Time: Fri Nov 20 20:46:48 UTC 2026
Total time taken to generate the page: 0.0058450698852539 seconds
