Toymods » General Car Talk » 3TGTE potential purchase...... what should i ask?
boris
On probation
Brisbane, Queensland
3TGTE potential purchase...... what should i ask? Thu, 22 January 2004 08:38 Go to next message
Ok heres the deal, im about to ring a guy that has a 3T that i wanna buy.... its not a private sale, its a business. what should i ask him about the engine and what things should i check to make sure that it is not a lemon? i've never done anything like this and am definately not mechanically enclined.
CLG
Perth, Western Australia
Re: 3TGTE potential purchase...... what should i ask? Thu, 22 January 2004 14:11 Go to previous messageGo to next message
Ask to see it running, if possible. definately compression test it, anything over 140psi is excellent, 110-140 acceptable, and under will be on the way to a rebuild. If you can't see it running or compression test it, assume it's to suit rebuild unless he gives you a warranty of good condition. If it's been sold with both computers, check to see all the plugs are there, along with all other fittings (AFM, sensors, ...), and that nothing is broken on the engine. Pull the rubber inlet pipe off the fron of the tubo, and check the compressor wheel - it should have not chunks taken out of the wheel, and have no side to side, or forwards and back play with light to light/medium touch and force. Look into the head area through the oil cap, is it relatively clean or dirty with black carbon deposits from lack of oil changes - if it is, the bearings won't be much better!!! Finally check the spark plugs are not immersed in oil which has leaked out of the rocker cover gasket, and if you can when compression testing, check all the spark plugs are uniform in colour and condition
boris
On probation
Re: 3TGTE potential purchase...... what should i ask? Fri, 23 January 2004 03:48 Go to previous messageGo to next message
cheers clint Very Happy
ThatDogsFullySickMate
BrisVegas---YeeeHAW
icon5.gif  Re: 3TGTE potential purchase...... what should i ask? Fri, 23 January 2004 10:08 Go to previous messageGo to next message
i was told you cant accurately compression test a motor by hand turning the crank as it wont spin up fast enough to create the correct and accurate compression reading Confused
boris
On probation
Re: 3TGTE potential purchase...... what should i ask? Fri, 23 January 2004 10:54 Go to previous messageGo to next message
right....
BrisVegas---YeeeHAW
Re: 3TGTE potential purchase...... what should i ask? Fri, 23 January 2004 11:37 Go to previous messageGo to next message
im not the guy who dosnt know what to ask when buying a motor Rolling Eyes
boris
On probation
Re: 3TGTE potential purchase...... what should i ask? Fri, 23 January 2004 11:48 Go to previous messageGo to next message
You don't have to be a smart arse... As you've stated and so have I, I don't know what to ask and Clint helped me out. You came along and contradicted him so i said right, hoping that somebody maybe even YOU Shocked could explain. These forums are supposed to be about helping fellow enthusiasts. No No No
BrisVegas---YeeeHAW
Re: 3TGTE potential purchase...... what should i ask? Fri, 23 January 2004 12:04 Go to previous messageGo to next message
right.
boris
On probation
Re: 3TGTE potential purchase...... what should i ask? Fri, 23 January 2004 12:11 Go to previous messageGo to next message
Laughing Laughing Laughing Neutral Twisted Evil
Seriously though ThatDogsFullySickMate can you explain what you meant and perhaps enlighten me as to how i would check the compression of an engine that cannot be started.
[Updated on: Fri, 23 January 2004 12:14]
BrisVegas---YeeeHAW
Re: 3TGTE potential purchase...... what should i ask? Fri, 23 January 2004 12:40 Go to previous messageGo to next message
sorry you just cant compression test a motor that way for a start a true reading the motor has to be hot, personally unless it comes with a warranty i wouldnt buy it
that just my 2 cents Smile
boris
On probation
Re: 3TGTE potential purchase...... what should i ask? Sat, 24 January 2004 05:01 Go to previous messageGo to next message
ok cool, well how do they show you it running? does it have to be in the half cut? I'll try and suss out warranty and all that sorta stuff.
CLG
Re: 3TGTE potential purchase...... what should i ask? Sat, 24 January 2004 07:11 Go to previous message
You can't compression test a motor by spinning it by hand, if it's not in a half cut (and I doubt it will be), you'll have to use a battery and the starter motor circuitry to spin it over. Yes, cold and hot compressions will vary, however the finally number will still be indicitive of the condition of the engine. I have quoted cold compression numbers above.
Previous Topic:This turbo will make many people envious(aka forget the T88)
Next Topic:Wanted - VERY well informed 3T/engine person
Current Time: Sat Oct 17 13:34:49 UTC 2026
Total time taken to generate the page: 0.007033109664917 seconds
