Toymods » Tech & Conversions » 2T block / 3T crank
Jonny2TG
Tasmania
2T block / 3T crank Sun, 04 August 2002 23:46 Go to next message
To save some money on my 3TG conversion (could be some time off yet), I will just buy a 3T crank, and grind the block to clear the con-rods. I have seen the result of this once before. Is there any disadvantage? Any reason to go for a 3T block? Grinding is no problem for me, as its probably less work since I won't have to change the dummy cam bearings.
Grega
melbourne.victoria.austra...
Re: 2T block / 3T crank Mon, 05 August 2002 09:06 Go to previous messageGo to next message
essentially the blocks are the same jonny, so i don't think it would make much difference - the only thing between them is the age dude.
TE72_Turbo
Re: 2T block / 3T crank Mon, 05 August 2002 09:11 Go to previous messageGo to next message
I've got a balanced 3TGTEU crank I might be willing to part with..... & a 3TGTE block also, but its been bored 20thou & honed.
Phil
Jonny2TG
Tasmania
Re: 2T block / 3T crank Mon, 05 August 2002 11:21 Go to previous messageGo to next message
Well let me know how much the 3T crank is.
Im in Hobart so I guess shipping a block would be a waste, expecialy when my 2TG block will do just fine, only with a little grinding.
TE72_Turbo
Re: 2T block / 3T crank Mon, 05 August 2002 13:27 Go to previous messageGo to next message
Well, It cost me $165 just for the balance. I had the bearing journals polished at the same time, and there are no scores in them, so I know its in good condition. What do you think about $150?
Jonny2TG
Tasmania
Re: 2T block / 3T crank Mon, 05 August 2002 13:34 Go to previous message
I think Im getting a 3T crank for $50, and will organise ballancing when the time comes. Thanks anyhow.
Previous Topic:Confict of fuel pump types! for 18RGU
Next Topic:7mgte vs 7mge oil pump ??
Current Time: Mon Oct 19 07:53:08 UTC 2026
Total time taken to generate the page: 0.057286024093628 seconds
