Toymods » Tech & Conversions » CT20B info
icon5.gif  CT20B info Thu, 22 January 2004 12:00 Go to next message
Ok I'm getting a manifold made up which will have my CT20B sitting with the flange facing down, but what I noticed was the oil feed and return line are not sitting on top. This obviously isn't going to allow the oil to drain away from the turbo so what I want to know is can the middle part of the turbo be turned around to have the oil feed/return lines on the bottom, but keep the turbine and compressor in the same position?
Hope that makes sense Confused Rolling Eyes
Re: CT20B info Thu, 22 January 2004 22:38 Go to previous messageGo to next message
Yup you can rotate the center Smile
Re: CT20B info Thu, 22 January 2004 23:01 Go to previous messageGo to next message
Is it easy to do? The turbine looks easy to turn but the compressor looks difficult Confused
Re: CT20B info Thu, 22 January 2004 23:23 Go to previous messageGo to next message
From memory the compressor has a large C kinda clip behind it with two rings/holes at the end of you.
There is a tool I brought to remove the clips that hold the gudeon(spelling?) pin in the piston. Anyhow that tool worked for the compressor as well.
But.... I dunno if its just my CT20-B or not but with it all bolted in place and supported I can hold onto the outlet and with enough force turn the compressor around by hand Smile
gabe
Re: CT20B info Thu, 22 January 2004 23:30 Go to previous messageGo to next message
TurboRA28 wrote on Fri, 23 January 2004 07:23
Circlip Pliars maybe?
Re: CT20B info Thu, 22 January 2004 23:53 Go to previous messageGo to next message
Ahhh thats the name I was after! Gotta excuse me its friday Smile
Re: CT20B info Fri, 23 January 2004 00:51 Go to previous messageGo to next message
Ahhh thanks. I'll have a closer look tonight and see if it has that large circlip.
Thanks again Smile
Stenno
Re: CT20B info Fri, 23 January 2004 00:58 Go to previous messageGo to next message
There will (should) also be a pin on either the compressor/turbine housings or the centre cartridge to aid with alignment - these will need to be either removed/moved (will require a new hole to be drilled to fit the pin(s)).
Re: CT20B info Fri, 23 January 2004 01:18 Go to previous messageGo to next message
Stenno wrote on Fri, 23 January 2004 10:58
I dont like the sound of that Confused
Stenno
Re: CT20B info Fri, 23 January 2004 04:42 Go to previous messageGo to next message
With the CT12B & CT26 the pins are located on the housings, whilst the centre cartridge has the actual holes that the pins go in.
Any decent machinist should be able to redrill the holes in the required spots however both wheels will be exposed during this process - you could get away with just removing the pins from the housings but you'll have to be carefull when you refit them to make sure they're lined up accordingly so the actuator fits on properly.
Darkstar
Ebbw Vale, Qld
Re: CT20B info Thu, 31 March 2005 04:30 Go to previous message
No Message Body
[Updated on: Thu, 31 March 2005 05:44]
Previous Topic:Wat sort of 4age??
Next Topic:Edit: 3T bore tolerances
Current Time: Fri Nov 20 08:01:10 UTC 2026
Total time taken to generate the page: 0.15634703636169 seconds
