Toymods » Tech & Conversions » how do you time an 78 corona 18R-C??
Trent-KE30
Tamworth NSW
how do you time an 78 corona 18R-C?? Thu, 22 January 2004 12:36 Go to next message
hey all, on my 78 corona 18R-C how do you time them i cant find the little symbol thing on the block to time it can i have some help as it is running like a dog
Trentelz
CLG
Perth, Western Australia
Re: how do you time an 78 corona 18R-C?? Thu, 22 January 2004 13:49 Go to previous message
There should be a little pointer on the timing chain cover, and a notch in the crank pulley. On number one compression stroke, the pointer and the timing notch should be closest to each other as the points in the dizzy are open at the plug for cylinder one.
you can find the compression stroke by removing the spark plug from the first cylinder, holding your thumb over the hole, then rotating the engine in it's normal direction till you feel the compression. Once you feel the compression keep rotating the engine till the pointer is closest to the notch. If you go past the notch, rewind the motor past the notch again, and retry, as the timing chains will need to be retensioned to give an accurate response.
Previous Topic:axle lash....
Next Topic:lukey mufflers.. exhaust people help.
Current Time: Sat Oct 24 00:20:44 UTC 2026
Total time taken to generate the page: 0.0079431533813477 seconds
