Toymods » Tech & Conversions » Testing impedance of spark plug leads
rvrolla
Central Coast
Testing impedance of spark plug leads Thu, 22 January 2004 21:18 Go to next message
Apparently, it should be about 4000 ohm per foot?
Is this correct? If so, how do I use the digital multimeter to test them? I switched it over to the impedance section, used the 200m? i think it was and unplugged the lead and stuck the meter on it. It came out at 15.9 or something. This was on the longest lead. So I thought 15.9 x 200 = 3180.
The shortest lead was about 1300. Is this bad or good? Am I doing it correctly!? Razz
Thanks fellahs ! Very Happy
sideshow
Re: Testing impedance of spark plug leads Thu, 22 January 2004 21:48 Go to previous messageGo to next message
put the multimeter on 20k
anything from 5k to 15 k resistance in the lead is ok
usually leads will either be good or open circuit
and if one lead is bad replace them all
the rest will go soon aswell
walu
Re: Testing impedance of spark plug leads Thu, 22 January 2004 22:13 Go to previous messageGo to next message
I have had all leads test fine with resistance, but still have one lead stuffed. Connections etc were all OK and it looked in good order as well. Replaced the lead and the problem went away.
rvrolla
Central Coast
Re: Testing impedance of spark plug leads Thu, 22 January 2004 22:23 Go to previous messageGo to next message
Thanks mate! I tried it in 20k and it showed nothing. It just came up with a 1 which I thought was too high reading for that setting? Sorry I don't know that much about the impedance settings Rolling Eyes
So if it was on the 20k setting it should show up anywhere between 5-15 on the screen? Confused
CLG
Perth, Western Australia
Re: Testing impedance of spark plug leads Fri, 23 January 2004 02:02 Go to previous messageGo to next message
Yep, thats right. You can test you've got your multimeter right by touching the probs - the readout will go to zero. I actually throw any lead with more than 10k out, but I have alot of leads, so can afford to be judicious.
ed_ma61
Lost in the K hole
Re: Testing impedance of spark plug leads Fri, 23 January 2004 02:12 Go to previous messageGo to next message
8.5mm MSD super conductors... 50ohm / foot Very Happy
rvrolla
Central Coast
Re: Testing impedance of spark plug leads Fri, 23 January 2004 02:42 Go to previous message
Ok, so if mine shows a 1, what does this mean? If I touch the probs together, then it shows a 0.00, which is correct. Maybe I'm not getting a good contact in the lead ends? When they aren't touching anything it shows the same, a 1.
Is 4000ohm correct?
And, is it 5 x 20k for the shorter leads and upto 10/15 x 20k for the long lead respectively?
thanks guys, appreciate the help!
ED: Those MSD's expensive? Would they really be worth it on a stocko NA 4 Banga?
Previous Topic:built in igniters
Next Topic:What pistons for a turbo Corolla?
Current Time: Sat Oct 24 10:04:48 UTC 2026
Total time taken to generate the page: 0.0074348449707031 seconds
