Toymods » Tech & Conversions » how to remove the stock tape/radio in an ma70
dingaling
tas
how to remove the stock tape/radio in an ma70 Fri, 23 January 2004 01:41 Go to next message
ok i've looked around and i can't really see how to remove this blasted old tape/radio which makes my battery go flat every time. It's so broken that it just plays non stop as if a tape is in it.
I've searched around on toymods and supraforums and i couldn't find info, i also checked the service manual with no luck.
I really really really hope it doesn't involve removing the whole dash!
wastegate
Gold Coast
Re: how to remove the stock tape/radio in an ma70 Fri, 23 January 2004 01:53 Go to previous messageGo to next message
You have to remove the black suround.
There is a screw under the hazards, as well as a screw on the side next to the shifter where your leg is.
If you have a manual you have to remove the gear knob.
If you have a Auto just put it in Drive or Neut.
Remove the ash tray.
Undo the two screws in the roof of the ash tray slot as well as the two side ones on the ash tray slot.
You can then remove the block dash cover.
Becareful of the hazard, window heater and cig lighter plugs, you will have to unplug them with "japhandbehinddash TM".
Once that is off you can remove the 4 screws holding the radio in. The whole Double Din unit then can come out.
dingaling
tas
Re: how to remove the stock tape/radio in an ma70 Fri, 23 January 2004 04:41 Go to previous messageGo to next message
wastegate thanx alot, otherwise i woulda ended up tearing my dash apart.
adamb131
Re: how to remove the stock tape/radio in an ma70 Fri, 23 January 2004 05:13 Go to previous message
http://members.swiftdsl.com.au/~mr2/pics/hammers.jpg
Previous Topic:7mge tuning, pinging, AFR's and other crap... LONG
Next Topic:18RG Gearboxes and hydraulic clutches
Current Time: Sat Oct 24 21:21:29 UTC 2026
Total time taken to generate the page: 0.004223108291626 seconds
