Toymods » Tech & Conversions » 18rg rebuild
silvercil40
18rg rebuild Fri, 23 January 2004 14:05 Go to next message
Its about time to rebuild my old 18rg, the timing chain is as tight as it will go. So....
New timing chain from a 308 right? Any model 308 or are they all the same?
How can i tell how much my internals have been worked once i pop the lid?
Any suggestions what i should do/replace/upgrade once i get into it?
Any advice/tips etc?
Cheers.
Mr DOHC
Re: 18rg rebuild Sat, 24 January 2004 03:04 Go to previous messageGo to next message
look at how worn the guides are and r u gonna do the whole lot or just the head
silvercil40
Re: 18rg rebuild Mon, 26 January 2004 10:54 Go to previous messageGo to next message
Not real sure yet, ive got to budget a few thing but am hoping to go the whole lot. Do 308 chains vary at all or will any do?
Jason
Re: 18rg rebuild Mon, 26 January 2004 23:58 Go to previous messageGo to next message
Try this place for parts http://www.swmotorsport.com.au/home.htm
silvercil40
Re: 18rg rebuild Tue, 27 January 2004 05:32 Go to previous messageGo to next message
Thanks for that Jason.
I most likely will be doing rings, bearings, timing chain and oil pump.
Anything else i should take a look at?
Jason
Re: 18rg rebuild Tue, 27 January 2004 06:14 Go to previous messageGo to next message
Possibly valves and you may as well do a quick port and polish Very Happy . And guides
Mr DOHC
Re: 18rg rebuild Tue, 27 January 2004 07:24 Go to previous messageGo to next message
definately get a valve grind done, as they will then do your valve stem seals at the same time,
not sure on the chains, i'll ask my dad soon
if u have a spare $250, get heavier springs and a set of regoround cams, do this b4 u get the valve lash set cause it will fuck it up
24 crt panny
Barossa Valley
Re: 18rg rebuild Wed, 28 January 2004 01:18 Go to previous messageGo to next message
Sorry to but in but as you have an 18 rg could you tell me if I get a new sump with the deepest bit at the front will I need to get a different oil pick up?once again sorry for butting in.
Re: 18rg rebuild Wed, 28 January 2004 01:45 Go to previous messageGo to next message
Yes, if you change the sump you'll need the matching oil pickup.
Mr DOHC
Re: 18rg rebuild Wed, 28 January 2004 08:15 Go to previous messageGo to next message
the bottom chain is a std 308 chain and the top one is a 152 link nissan unit that u have to shorten, like $30 for the 308 one and about 40 for the other one and $2 for the joiner link
24 crt panny
Barossa Valley
Re: 18rg rebuild Thu, 29 January 2004 00:57 Go to previous messageGo to next message
OK cheers Norbie
Steve M
Re: 18rg rebuild Thu, 29 January 2004 03:17 Go to previous messageGo to next message
about the chains.
There are good chains and then there are bad chains.
A common practice now is for companies to make the rollers from curled sheet metal. It is hard to see the difference, but you can see small slits in the rollers.
This is bad, occasionally one will fail under the pressure and you can end up with a fairly disasterous timing chain failure.
It is well worth the effort finding chains without split rollers.
Many of the AUS made chains are split, whereas the JAP chains tend to not have split rollers.
wil8115
Seattle area, USA
Re: 18rg rebuild Tue, 09 March 2004 08:46 Go to previous messageGo to next message
bottom timing set is same as the 18RC.
top chain is a 98 link dbl row.
Same top chain for 2TG's.
I believe the 21R timing chain will work. But you would have to count it first to make sure. Here in the states we use a 20R chain or "tall deck" early 22R chain. the 21r should be the same though. Which i think you guys got. The chain guides are re-usable is the grooves aren't to deep.
HTH.
Smile
[Updated on: Tue, 09 March 2004 08:48]
people100
Rocklea qld
Re: 18rg rebuild Tue, 09 March 2004 10:00 Go to previous messageGo to next message
Who is actually gonna do the work for ya. Im sure if you supply enough alchomohol then me and phil can get it done for ya. Try supercheap as they do have the list for a 18rg in there books but not sure what they actually sell.
raistlin
Re: 18rg rebuild Tue, 09 March 2004 22:43 Go to previous messageGo to next message
Robertson Bros in Mayfield can get their hands on pretty much anything for an 18RG. They got all my gear for me as well as doing my head work...
Mr DOHC
Re: 18rg rebuild Wed, 10 March 2004 07:46 Go to previous messageGo to next message
people100 wrote on Tue, 09 March 2004 20:00
great, i'm being pimped out by ben Confused
wil8115
Seattle area, USA
Re: 18rg rebuild Wed, 10 March 2004 07:58 Go to previous message
Can they get over sized replacement pistons?
I can source pretty much everything else i need over here but the pistons. btw do you have their contact details? Im in the states. thanks.
Previous Topic:AE86 Sprinter SR20DET conversion?
Next Topic:Tailshaft Loop - Toynats
Current Time: Wed Nov 18 22:32:18 UTC 2026
Total time taken to generate the page: 0.0079150199890137 seconds
