Toymods » Tech & Conversions » 1JZ & Auto aftermarket ecu
MRJZX
1JZ & Auto aftermarket ecu Sat, 24 January 2004 02:06 Go to next message
Does anyone know of an ecu that can run the 1jz with auto (A340E) in this case.
Or is the only option to use things like SAFC's.
sideshow
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 04:13 Go to previous messageGo to next message
where r u from
y do u need an aftermarket ecu
are u goin to run alot of hp
u can keep it all std if u only want abit of a rise in hp
ive wired up the std ecu afew times just for the auto
then the guys just run an aftermarket ecu just for fuel and ignition
it is piggybacked of the ignition wires and injector wires
and the crank trigger signals
unless u get a motec which can control yr auto
theres really no way of gettin it perfect
[Updated on: Sat, 24 January 2004 04:15]
MRJZX
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 04:38 Go to previous messageGo to next message
I'm in NZ.
I'm will be after an ECU because I have a HKS 3240 turbo kit to fit.
sideshow
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 05:00 Go to previous messageGo to next message
ok
u can always go manual gbox
or get an ecu that can do the automatic aswell
the problem is u have overdrive switch and the power/economy switch
also u have speed sensor which is used to get the auto to change gears
these wires go into the ecu and then the engine ecu controls the auto
slylux
perth WA
    nup
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 07:03 Go to previous messageGo to next message
OR maybe try this ..
http://users.bigpond.com/K_Dog/engconversion/FAQ.h tm
Chris Davey
sunny coast, qld
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 07:36 Go to previous messageGo to next message
So for someone that doesn't want to go single turbo for quite a while but wants to alter fuelling, get rid of speed cut, boost cut and fuel cut, what would be the best option? (Will i need boost cut and fuel cut defenders to run 15psi?)
S-AFC and some defenders
or
Programmable computer piggybacked onto standard ECU to run fuel and ignition.
Money is an object Smile
sideshow
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 09:53 Go to previous messageGo to next message
u have a std ecu dont u bass
then all u need is to run say a microtech or ems as a piggyback
use the std ecu to run the gbox and externals
then use the aftermarket ecus to run injectors and timing
its been done afew times and i know it works
Chris Davey
sunny coast, qld
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 09:58 Go to previous messageGo to next message
thanks for that.
the only thing i was worried about is the cost of tuning an aftermarket ECU compared to just fitting a SAFC that comes with a base map. But for the price of an LTX12 or a wolf 3d compared to a SAFC and all the assorted defenders, i think it is a better idea to go aftermarket ECU.
sideshow
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 10:16 Go to previous messageGo to next message
tunin a safc is still costly if u want to tune it properly
i way prefer aftermarket ecu to a safc
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 12:24 Go to previous messageGo to next message
bassaholic55 wrote on Sat, 24 January 2004 17:36
<big snip>
budget version then?
-Megsquirt - squirt-n-spark version (aux air hard wired to cold-start sensor and A/C controller only)
-k-dog's sequential gearbox controller
a groupbuy megsquirt costs you about $350 - you have to join the oz megasquirt list to find out when next buy is happening.
k-dog's controller costs $350 - plus what ever work you do to the gearbox - works on A340E/A341E/A342E gearboxes.
both of these require skill in building/wiring electrical equipment - plus allow another $300 for bits-n-pieces.
ECU is tuned with a laptop - if the engine has a dizzi, you lock any mechanicals in it and use the reluctor sensing 6 triggers per dizzi revolution - if it's coilpacks, then import 6cyl EDIS parts from the US and run squirt-n-EDIS code on the ECU.
i'll be doing this with my 1G-GTE and running the auto box as a sequential unit.
MRJZX
Re: 1JZ & Auto aftermarket ecu Sat, 24 January 2004 18:54 Go to previous messageGo to next message
Looks like manual might have to be the go.
I've found a JZX81 in Japan that runs the stock ecu with a HKS FconV Pro.
This is going to get expensive I think.
I might see if I can get an Haltech to piggyback the stock ecu
Re: 1JZ & Auto aftermarket ecu Mon, 26 January 2004 03:18 Go to previous messageGo to next message
MRJZX wrote on Sat, 24 January 2004 13:06
Motec M800. All you need is the hysteresis points for the auto.
sideshow
Re: 1JZ & Auto aftermarket ecu Mon, 26 January 2004 03:27 Go to previous messageGo to next message
by the time u finish installina nd tunning the motec u might end up payin about 4000 bucks
thats its only downfall
its cheaper to run std ecu and a piggyback ecu
Celia-Sue
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 04:55 Go to previous messageGo to next message
I've been ponering this one all week ....
How would you use the Motec to run the auto? And if it's just by plugging the sensors and aux. inputs/outputs through the Motec, couldn't you do the same thing with a Haltec E6X?
cheers,
Justin
JZA61
sideshow
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 06:30 Go to previous messageGo to next message
mot3c has digital inputs and outputs
its bit technical but can be done
dont know bout latest haltech
but i dont know of any haltech that will do auto changes
motec is only aftermarket ecu that will do engine and auto gbox
in one unit and expect to pay alot for it
Celia-Sue
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 06:46 Go to previous messageGo to next message
Ah-ha. Thanks heaps, Mr. Sideshow Smile
I still haven't been able to find an auto JZX90 wiring diagram and my auto-electrician is getting a bit nervous about the 3-odd kilometeres of spaghetti that he has to wire in.
So, I'm just thinking about some alternatives - like either the Motec or K-Doggs standalone and a mid-level ECU. I'd have to see if the engineer would be OK with that first. Hmmmm ...
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 06:49 Go to previous messageGo to next message
You need to setup a speed sensor and then create a 'table' using speed and 'engine load' (TPS). You then use it to control outputs to switch the auto. It is not simple as you have to set it up across a large range of variables to create the hysteresis points, and it takes about a day of dyno time (according to the tuner). Read exxy.
Like Sideshow has said, probably not worth your while if you are sticking to standard everything.
I can't comment about the Haltech.
sideshow
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 07:55 Go to previous messageGo to next message
the auto is easy to wire up on a 1jz
all the auto wires should be in the factory loom
all u have to add is the speed sensor signal form the dash
the overdrive signal from o/d switch
and a power/economy switch
im sure theres a 1jz specs website somewhere
try here
http://www.1jz-gte.us/92Supra6.html
i have done afew with auot and std ecu and have had no probs that i couldnt fix
Celia-Sue
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 08:08 Go to previous messageGo to next message
Sadly, that's the single turbo VVTi JZX100 diagram. Sad
It's no so much the auto, but the whole lot that is hard without diagrams - it has all that ABS, traction control, etc. Hence, if we could go after-market ecu & geabox controller - wiring would be easier and it would beat the hell out of stock unit and piggyback A/F interceptor.
Whatcha reckon?
sideshow
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 08:14 Go to previous messageGo to next message
does it have 4 big plugs on the ecu
each plug has 4 rows of wires
these are like a jzz30 i think
i dont know why they would be much different
abs thro away
traction thro away
wont cause any probs
only prob u might have is the speed sensor signal
depends how it all works
std is much better if u are not goin to boost it heaps
send me loom and i can fix it for u
i can label everything aswell
[Updated on: Fri, 30 January 2004 08:14]
sideshow
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 08:35 Go to previous messageGo to next message
i just looked at my little book
only thing i can find is that the vvti 1jz is from a jzx 110
and it has big computer for engine and another big ecu for auto
what ecu configuration do u have
do u have one ecu that does engine and auto
Celia-Sue
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 08:51 Go to previous messageGo to next message
Mine looks suspiciously like the (4row x 4plug) JZZ30. And nothing like the JZX100 - which I'm pretty sure is the VVTi Ct20 with AFM, though I'm no expert on Chaser nomenclature.
sideshow
Re: 1JZ & Auto aftermarket ecu Fri, 30 January 2004 08:54 Go to previous message
the jzz30 is easy to find info on
that computer does both the engine and auto
most of the auto wiring should be intact with the engine loom
i hope yr electrician hasnt split the engine loom apart aswell
Previous Topic:GA-70 (1G-GTE) Ignition timing questions
Next Topic:Removing boot lock
Current Time: Sun Oct 18 03:00:44 UTC 2026
Total time taken to generate the page: 0.28681898117065 seconds
