Toymods » Tech & Conversions » How much boost does a NEVO pulley make?
Spanktown
Inside a giant turbo (syd...
icon4.gif  How much boost does a NEVO pulley make? Sat, 24 January 2004 05:41 Go to next message
Ive recently purchased and installed a NEVO 175mm oversize pulley on my gze. It ran 7psi stock, once the pulley was installed without any abv modification it still made 10psi, so i did the ABV mod and was expecting it to reach something like 12-14psi?? but it just stays on 10psi. What do you guys get?
[Updated on: Sat, 24 January 2004 08:00]
old_mr2
Re: How much boost does a NEVO pulley make? Sat, 24 January 2004 09:12 Go to previous messageGo to next message
please reply guys I am also dying to know. I am about to go nevo myself.... thanks
Spanktown - is the difference in horsepower good? does it give you a good boot up the ass??
DiZ_
The Eastwood MASSIVE !
Re: How much boost does a NEVO pulley make? Sat, 24 January 2004 10:58 Go to previous messageGo to next message
Two of my mates have it and they get 12.
Anything less and you have a leak.
faulksy
Re: How much boost does a NEVO pulley make? Sat, 24 January 2004 11:39 Go to previous messageGo to next message
sounds about right. i have 10psi with mine but i know i have a leak
Spanktown
Re: How much boost does a NEVO pulley make? Sat, 24 January 2004 14:20 Go to previous messageGo to next message
a leak? where should i look. it was boosting fine ie stock was like 7psi, isnt that right?
krayzie
Re: How much boost does a NEVO pulley make? Sat, 24 January 2004 23:01 Go to previous messageGo to next message
I get almost 10psi in standard form ..... I would say you have a boost leak somewhere.
feral4mr2
Bundaberg, Qld.
Re: How much boost does a NEVO pulley make? Sat, 24 January 2004 23:30 Go to previous messageGo to next message
Freak make sure the belt isnt slipping.
when mine was slipping (i only had a 160mm pulley) when i was planting it, i would see boost fly up and then it'll stop earlier than it should even though the revs where still climbing. normaly happen in the upper rev range. (5000rpm + ).
slipping s/c belt most times sounds like air noise, not like the squeal you get with a lose alt belt on the older cars.
plus i wouldnt get full boost until the car was flying along the road, more air flow i spose.
Spanktown
Re: How much boost does a NEVO pulley make? Sun, 25 January 2004 00:49 Go to previous messageGo to next message
I followed the instructions from that mr2sc site, removed the lines from the blue vsv, plugged the TB one and T'd the ABV one into the line i have my boost guage on. Thats right isnt it?
feral4mr2
Bundaberg, Qld.
Re: How much boost does a NEVO pulley make? Sun, 25 January 2004 01:01 Go to previous messageGo to next message
Freak sounds right to me. Smile
Spanktown
Re: How much boost does a NEVO pulley make? Sun, 25 January 2004 11:14 Go to previous messageGo to next message
so how do i check for leaks? where is the most prone? the IC piping joins?
JDM hachi
was adelaide now newcastle
Re: How much boost does a NEVO pulley make? Sun, 25 January 2004 21:42 Go to previous messageGo to next message
what type of intercooler are you using?, by the sounds of it you are measuring boost after the intercooler, thus a certain degree of pressure drop has occured, the larger pulley will probably make higher measured boost at the sc outlet, but best to check belts, and hoser clamps anyway,
matty.
Spanktown
Re: How much boost does a NEVO pulley make? Mon, 26 January 2004 02:02 Go to previous messageGo to next message
Stock intercooler on a bog stock SC jap import aw11 mr2. Im measuring the boost in the same place as everyone else, I got 7 pounds before and now 10 pounds after 175mm Nevo and ABV mod. By the sounds of things 12psi seems the norm, so ill check the hose clamps etc.
Spanktown
Re: How much boost does a NEVO pulley make? Mon, 26 January 2004 13:07 Go to previous messageGo to next message
I got 11psi at about 6500rpm in second today, when do you reach 12psi with your gze's?
Ben Wilson
Re: How much boost does a NEVO pulley make? Mon, 26 January 2004 22:44 Go to previous messageGo to next message
I get about 11.5 psi in second with my AW11 motor, but, I'm running a later supercharger pulley.
Spanktown
Re: How much boost does a NEVO pulley make? Tue, 27 January 2004 00:03 Go to previous messageGo to next message
what do you mean a later pulley?
slydar
Re: How much boost does a NEVO pulley make? Tue, 27 January 2004 00:26 Go to previous messageGo to next message
try spraying a mist of water (with like a haridressers type bottle) around areas where you think it might be leaking while the car idles. this method can be used to find vacumm leaks, but at idle, there should be some vacumm in youre IC plumbing maybe? you could try it.
Ben Wilson
Re: How much boost does a NEVO pulley make? Tue, 27 January 2004 00:32 Go to previous messageGo to next message
Spanktown wrote on Tue, 27 January 2004 11:03
The later ZE motors used a smaller pulley on the supercharger to give about 1 lb more boost.
Spanktown
Re: How much boost does a NEVO pulley make? Tue, 27 January 2004 10:42 Go to previous messageGo to next message
so yours is stock except for a smaller sc pulley? would of thought my increase would of been bigger, well it does feel bigger, but isnt showing like it is. Confused
tin can
Re: How much boost does a NEVO pulley make? Tue, 27 January 2004 10:51 Go to previous messageGo to next message
try piping from s\c to i\c and u well hear revs drop
Ben Wilson
Re: How much boost does a NEVO pulley make? Tue, 27 January 2004 21:11 Go to previous messageGo to next message
Spanktown wrote on Tue, 27 January 2004 21:42
Sorry - I'm running the big NEVO pulley as well as the smaller supercharger pulley. I do have an ARC intercooler which might be making a difference as well....
7M-Brisbane
Re: How much boost does a NEVO pulley make? Tue, 27 January 2004 23:26 Go to previous messageGo to next message
Boost should always be measured post-throttle (normally off the inlet plenum), as this is the amount of boost that the engine actually sees.
The only time you should be measuring boost anywhere else is if you are trying to ascertain the pressure drop between certain parts of your inlet system.
In this sitation it may be worthwhile connecting a second boost gauge pre-intercooler and having someone watch it for you (eyes on the road, please!) to see if there is any difference between the two. A crap intercooler will generate crap results...
Ben Wilson
Re: How much boost does a NEVO pulley make? Wed, 28 January 2004 01:16 Go to previous message
Post throttle in a ZE isn't the same as a turbo car (the TB is before the supercharger).
For the record, I'm measuring boost at the inlet manifold.
Previous Topic:2T-G -> KE20, potential?
Next Topic:turbo specialists: Western Sydney
Current Time: Sun Nov 1 04:10:17 UTC 2026
Total time taken to generate the page: 0.05913782119751 seconds
