Toymods » Tech & Conversions » 1jz timing belt..help?
bowlsclubboy
N/E Vic
1jz timing belt..help? Sun, 25 January 2004 06:02 Go to next message
Okay...heres a reccomendation for anyone thinking about doing their own timing belt. Make sure that you get a rattle gun and have the compressor running about 130PSI. My brother and i tried to remove the harmonic balancer with a big breaker bar hanging off the crank bolt, and another hanging off one of the cams. Well we skipped a tooth or a few Sad and there doesnt seem to be any markings on the timing belt housing to line the crank pulleys up with once we get No1 TDC. Anyone done their own timing belt before and can gimmie a clue?
Troy
Re: 1jz timing belt..help? Sun, 25 January 2004 06:54 Go to previous messageGo to next message
uuummmm
did you read any posts on this before hand? Smile
I'm about to do the same thing
the 3 things I've learnt are:
1. put engine to TDC
2. Make sure crank is close to 0 degrees
3. Make sure you mark where the 2 notches in the cams are
otherwise you're going to have fun
(sorry, I realise this isn't very helpful:))
Siktoy ra23
Plumpton/sydney
Re: 1jz timing belt..help? Mon, 26 January 2004 10:39 Go to previous message
Usualy the marks go to the top of the motor, well that is how the 1g and 18rg are Smile
Previous Topic:GZE belt slip
Next Topic:RA60 Headlight Problem
Current Time: Sat Oct 31 19:07:47 UTC 2026
Total time taken to generate the page: 0.0043880939483643 seconds
