Toymods » Tech & Conversions » how do i know if my fans work?
V8_MA61
how do i know if my fans work? Sun, 25 January 2004 09:30 Go to next message
Hi Guys,
Need some help/ advice about testing my thermos and their operating condition.
I have them hooked up thermally, and have just put the engine back together.
How do i test if they are working without waiting for the engine to warm up, worrying myself if they dont work, my car will cook??
Its an sv21 camry/ ae92 corolla switch - 90" i think.
Blake
SW20R
Re: how do i know if my fans work? Sun, 25 January 2004 09:39 Go to previous messageGo to next message
unplug the switch ontop of the thermo it should run full time
but yeah.. you'll have to check the manual for resistance and stuff try the tomods gallery - tech docs - and just browse any car manual and look for the cooling system etc
Re: how do i know if my fans work? Sun, 25 January 2004 09:43 Go to previous messageGo to next message
is that a heat up and open switch?
you can unplug the switch, and the fans should turn on. OEM was designed this way in case circuit to switch failed.
other way is to pull the sensor, and dump it in hot water.. it may not get hot enough straight away, so either letting warm up in container of just boiled water, and then pouring hot water over it may do the trick, OR use heated oil (like cooking oil) but be frickin careful...
then check for continuity between switch and engine block when switch is installed and cold (since it has to conduct to turn the relay on to open circuit to make fans stop...)
or just let motor idle while watching temp gauge, and seeing when they turn on.
V8_MA61
Re: how do i know if my fans work? Sun, 25 January 2004 09:47 Go to previous messageGo to next message
Stewart - yeah its an open up when hot switch
do you think the turn on point of the sv21's switch, would be about 1/2 way on the ma70 gauge? Confused Anyone used this switch on an ma70 to find out?
[Updated on: Sun, 25 January 2004 09:48]
Re: how do i know if my fans work? Sun, 25 January 2004 12:33 Go to previous messageGo to next message
Dude, practically all engines run at the same or similar temperature. A variation of a few degrees makes fuck-all difference anyway. Just make sure the circuit works correctly (ie manually trip it and make sure the fans are spinning, and in the right direction) and it will be all good.
V8_MA61
Re: how do i know if my fans work? Sun, 25 January 2004 12:53 Go to previous message
thanks mate. Thats all i needed to know.
Previous Topic:Help
Next Topic:turbo line Q's
Current Time: Fri Nov 20 16:54:02 UTC 2026
Total time taken to generate the page: 0.0050809383392334 seconds
