Classifieds » Miscellaneous » 2J turbochargers and other misc bits.
Stenno
2J turbochargers and other misc bits. Sun, 25 January 2004 09:37 Go to next message
2 x CT12B turbochargers - immaculate condtion, less than 50,000kms (if that) on these turbos.
Includes soleniods, pressure tank, top outlet piping (with bypass valve) and oil drain pipes.
$800 negotiable.
CT-26 off 7M-GTE, reasonable condition. *SOLD*
1 Air conditioner pump to suit 7M-GTE (MA71) *SOLD*
89750 14010 Front spoiler controller $20?
89540 14060 Computer Assembly - traction control Computer (the 1 that sits behind the centre console) $20?
2JZ Engine mounts (dampers & alloy mounts) $150 negotiable for the pair.
Silicone reducer 2.5" to 2.0" $25?
Standard 1JZ/2JZ cam gears $80 ONO for the pair.
Bosch compressor bypass valve $20
Pictures can be found here
[Updated on: Thu, 29 January 2004 05:19]
Stenno
Re: 2J turbochargers and other misc bits. Mon, 26 January 2004 10:17 Go to previous messageGo to next message
Also have 2 Autometer gauges,
Autometer Phantom Mechanical Boost gauge, in original packaging - $60. will require Autometer P/N:3223 (Nylon tubing with Fittings & Ferrules) $20 from Autospeed.
Autometer Phantom Electric Oil Pressure gauge (0-100psi) in original packaging. Missing sender, $50. requires Autometer P/N:2242, $70 from Autospeed.
mrsmart
Melbourne Eastern Suburbs
Re: 2J turbochargers and other misc bits. Mon, 26 January 2004 10:37 Go to previous messageGo to next message
PM sent re ct26.
isaac
Helensvale, Queensland
Re: 2J turbochargers and other misc bits. Tue, 27 January 2004 01:23 Go to previous messageGo to next message
Will the CT26 off the 7M bolt straight up to a 3SGTE exhaust manifold, or are they different? Thanks
Stenno
Re: 2J turbochargers and other misc bits. Tue, 27 January 2004 02:43 Go to previous messageGo to next message
isaac wrote on Tue, 27 January 2004 12:23
I thought the bolt pattern was different between the 2 exhaust housings but I'm not sure, the CT26 has been sold.
ReQuieM
Re: 2J turbochargers and other misc bits. Tue, 27 January 2004 04:52 Go to previous messageGo to next message
do the ct12B's fit in the stock 1j spot? the B's are bigger then the 1J A's yeah?
Stenno
Re: 2J turbochargers and other misc bits. Tue, 27 January 2004 06:34 Go to previous messageGo to next message
Unfortunetly not, add to the fact the second turbo doesn't have a wastegate and it would make things interesting even if they could be swapped.
In answer to the sizing of them, they're a bigger turbo than the CT12A.
ReQuieM
Re: 2J turbochargers and other misc bits. Wed, 28 January 2004 01:14 Go to previous messageGo to next message
yeah i figured, other wise "every one would of done it by now"
Stenno
Re: 2J turbochargers and other misc bits. Sun, 01 February 2004 00:09 Go to previous messageGo to next message
ReQuieM wrote on Wed, 28 January 2004 12:14
Exactly, if it could be done easily it'd be a good upgrade over the CT12a's, but sadly it's not.
Stenno
Re: 2J turbochargers and other misc bits. Thu, 12 February 2004 09:32 Go to previous messageGo to next message
*bump*
mx83toy
Re: 2J turbochargers and other misc bits. Thu, 12 February 2004 12:22 Go to previous messageGo to next message
i'll take the boost gauge... pm me your number
[Updated on: Thu, 12 February 2004 12:25]
Stenno
Re: 2J turbochargers and other misc bits. Mon, 01 March 2004 12:17 Go to previous message
mx83toy wrote on Thu, 12 February 2004 23:22
PM sent.
*bump*
Previous Topic:7mge and gearbox 600 o.n.o
Next Topic:ST184 K&N drop in air filter
Current Time: Mon Nov 23 19:49:31 UTC 2026
Total time taken to generate the page: 0.0061399936676025 seconds
