Toymods » Tech & Conversions » Help on 17" ROH Adrenaline
rebbot
Crawley, WA
Help on 17" ROH Adrenaline Sun, 25 January 2004 12:31 Go to next message
Hi guys,
I'm about to get a set of 17" ROH Adrenaline rims with Yokohama ES100 tyres (215/45R17)...I know the PCD is correct as its 5 nuts 114.3 but I not very sure about the offset as its not stated. Does anyone know or does the offset even matter? Thanks in advance!
Btw I drive a 1989 mkiii supra twin turbo...
Some pics to see if they are worth it Smile
http://forums.toymods.org.au/index.php?t=getfile&id=3018
http://forums.toymods.org.au/index.php?t=getfile&id=3019
[Updated on: Tue, 27 January 2004 14:28]
Soarer
Wollongong
Re: Help on 17" ROH Adrenaline Mon, 26 January 2004 04:19 Go to previous messageGo to next message
Offset does matter. I believe the JZA70 uses +45-50 offset (from memory).
You can measure the offset yourself. I could explain it here, but it would take me a while. I'm sure Google would be able to help out though.
rxtoy
Auckland NZ
Re: Help on 17" ROH Adrenaline Mon, 26 January 2004 10:00 Go to previous messageGo to next message
afaik (correct me if i'm wrong, i know you want to Very Happy )the only wheels that came out with that stud pattern (hilux, rx7's, 300zx's?, maybe a few more) were all rwd so the offset should be pretty damn close. the only way to know for sure that they'll fit would be to try them though
Re: Help on 17" ROH Adrenaline Mon, 26 January 2004 11:51 Go to previous messageGo to next message
It's easier to explain measuring offset with a pen and paper, go to the place you're buying the wheels from, and get them to run through it with you. If they don't know, then buy your wheels elsewhere, because they're obviously not too bright! Evil or Very Mad
Classique71
Colac, Victoria
Re: Help on 17" ROH Adrenaline Mon, 26 January 2004 12:28 Go to previous messageGo to next message
and if they charge liek a wounded bull - look at performance tempests
nearly identical in shape - and cheaper !!
Thats what i have on my Gt4 - See avatar ..
mine are 16's in the silver finish ( cant get the hyperchrome )
rebbot
Crawley, WA
Re: Help on 17" ROH Adrenaline Tue, 27 January 2004 13:02 Go to previous messageGo to next message
Btw I found my offset Very Happy they are 37mm but I still cannot find the offset for the ROH rims Sad
I am unable to bring my ride down as I am not in aussie Mad I'm on holiday though and came across this guy selling his rims and tyres for only $300 Shocked That's why I am anxious to get them So anyone know the offset for the ROH rims?
Re: Help on 17" ROH Adrenaline Tue, 27 January 2004 13:24 Go to previous messageGo to next message
A = total width of rim (not tyre)
B = depth from inside rim to face where stud plate bolts up.
C = A / 2 (distance from rim to centre of rim)
offset = C - B (how far the stud plate is from the rim centre)
positive means plate is closer to outside of rim
negative means plate is cloers to inside of rim
ta23
Re: Help on 17" ROH Adrenaline Tue, 27 January 2004 13:29 Go to previous messageGo to next message
rebbot wrote on Wed, 28 January 2004 00:02
Buy them anyway, I am sure you will be able to sell for alot more if they dont fit on your car Smile
rebbot
Crawley, WA
Re: Help on 17" ROH Adrenaline Tue, 27 January 2004 13:31 Go to previous messageGo to next message
Thanks Dude! You are the best! Shall get the guy to measure based on your method...
Also another question does it matter if the rims ar 17X7, 17X8 or 17X9? Can we see which is it based on the tyres? They are Yokohama ES100 tyres (215/45R17). Thanks again dude!
rebbot
Crawley, WA
Re: Help on 17" ROH Adrenaline Tue, 27 January 2004 13:32 Go to previous messageGo to next message
But the thing is I need to sea freight them back to WA...by the time its reaches hm it will probably cost me ard $200+ more Sad
rvrolla
Central Coast
Re: Help on 17" ROH Adrenaline Wed, 28 January 2004 02:21 Go to previous messageGo to next message
Classique71 wrote on Mon, 26 January 2004 23:28
Im sorry Classique71, but I have to do this. I owned a set of Performance Wheels Tempest, and they are really bad. The first set I had, I used [/b]expensive[/b] Meguires mag wheel cleaner on them (thinking I was doing the right thing) and the paint run as soons as it was sprayed on. I then took them back for warranty, which took several months (no joke!), and they repainted them, then tried to charge me!! The whole time I was told they were being done under warranty.
Second set. Didn't EVER touch them with ANY cleaners at all excpet slightly soapy water and a soft sponge. The paint went from the nice silvery colour to a dull grey. I figured it was the brake dust sitting and drying on the wheels. They didnt go as bad as the first set, but now one of my girlfriends, friends my old Corolla, and they are literally black now. Typical chick i spose Razz but she never cleans them or anything. So the paint has just totally disappeared.
I have seen several other cars with different types of PErformance Wheels with the Hyperchrome finish and the same thing has happened to them all.
I hope this doesnt happen to you mate! Sorry! Embarassed
Classique71
Colac, Victoria
Re: Help on 17" ROH Adrenaline Wed, 28 January 2004 03:34 Go to previous messageGo to next message
mine are not hyperchromed - they are just plain old silver - like 95 % of the mags out there Smile
I heard about the issues with the hyperchrome - and said F that !
they have withdrawn hyperchrome from their catalogue now ( checked on this too ) mainly because the finish wouldnt adhere to the alloy ..
the platinum and silver finishes are fine though - no problems there.. ( checked on this too ! )
ive had no issues with mine so far - none whatsoever .. And i drive on some of australias shittiest roads on a daily basis Wink
rvrolla
Central Coast
Re: Help on 17" ROH Adrenaline Wed, 28 January 2004 08:04 Go to previous messageGo to next message
Thats good to hear!!
They still list the hypercrap on their website, but wouldn't surprise me if they have removed it. It was shite!
They look good on the GT4 though!!
Classique71
Colac, Victoria
Re: Help on 17" ROH Adrenaline Wed, 28 January 2004 09:11 Go to previous messageGo to next message
Thats why i bought them - and they cost a grand less than 17 inch roh adrenalins - which would also have looked awesome but thats a BIG increase for wheels of near identical look
T APLUS 22
Re: Help on 17" ROH Adrenaline Wed, 28 January 2004 12:59 Go to previous message
there should be a marking on the rim. Possibly a number then a letter eg '4N'. Then let a wheel shop that stocks ROH know and they will tell you.
With a width of 215 tyre, they are 7" or 8".
Previous Topic:What seats fit an ae92?
Next Topic:do corolla boss kits fit aw11s?
Current Time: Mon Nov 2 14:36:14 UTC 2026
Total time taken to generate the page: 0.10138297080994 seconds
