Toymods » Tech & Conversions » 1GGTE UPGRADES
Darkstar
Ebbw Vale, Qld
1GGTE UPGRADES Sun, 25 January 2004 13:01 Go to next message
I have recently put a 1ggte into a '90 cressida and was wondering what some 'bolt-on' upgrades would be. If possible running stock turbos etc. What boost can u safely run with standard set-up anyway???
Any suggestions would be great thanks
Re: 1GGTE UPGRADES Sun, 25 January 2004 13:23 Go to previous messageGo to next message
The stock turbos are the bottleneck on a factory 1G, so if you don't replace them there's not much point upgrading anything else... apart from intercooler perhaps, but you're not going to find a "bolt on" item for a Cressida!
Siktoy ra23
Plumpton/sydney
Re: 1GGTE UPGRADES Mon, 26 January 2004 10:34 Go to previous messageGo to next message
Start with an aftermarket ecu and as norbie said an I/C is also a very good idea.
I am running about 15 psi on stock gear and it is holding together very well
Darkstar
Ebbw Vale, Qld
Re: 1GGTE UPGRADES Tue, 27 January 2004 12:12 Go to previous messageGo to next message
what would be a suitable upgrade for the turbos eg a pair of ct-26 or what? What would have to be modified?
Re: 1GGTE UPGRADES Tue, 27 January 2004 13:06 Go to previous messageGo to next message
Darkstar wrote on Tue, 27 January 2004 22:12
bigger turbos would probably mean:
custom or modded exhaust manifold and dump pipe(s)
modified air intake
improved injectors
aftermarket ECU
exhaust
not really 'bolt on' stuff tho ...
Re: 1GGTE UPGRADES Tue, 27 January 2004 14:24 Go to previous message
I wouldn't recommend a pair of CT26's on a 2 litre engine, unless you really like turbo lag! A single CT26 (from a 7M) would be a good upgrade if you're on a budget. All of the above applies though; it's not a simple matter of bolting on a turbo and driving away unfortunately.
Previous Topic:1JZ RA23
Next Topic:Reshaping brake pads
Current Time: Fri Oct 30 15:17:51 UTC 2026
Total time taken to generate the page: 0.0054950714111328 seconds
