Toymods » Tech & Conversions » How can i work my 4K motor?
marty
Blue Mountains
How can i work my 4K motor? Mon, 05 August 2002 09:01 Go to next message
hey i have a Ke25 corolla coupe and im putting a 4K into it and im thinking of adapting a 3K head on the 4k block for a higher compression ratio i need some advice on how i may be able to work it harder than just that i have a set of twin 1 inch Su's
and a set of 2 inch extractors i need some advice on more work i can do and how much power i will increase i to by doing what i have just said any information would be gratefully apreciated
Marty
Grega
melbourne.victoria.austra...
Re: How can i work my 4K motor? Mon, 05 August 2002 09:11 Go to previous messageGo to next message
could try throwing in a cam, here are some specs :
http://www.angelfire.com/vt/commodoress/rolla.htm
Re: How can i work my 4K motor? Mon, 05 August 2002 12:37 Go to previous messageGo to next message
3K head, port it a bit, twin carbs, some headers + 2" exhaust, electronic ignition, and a cam
So long as you can do as much as possible yourself so that it won't cost too much, otherwise might just want to look at a 4ag (theres a reason that ideas been done to death!)
marty
Blue Mountains
Re: How can i work my 4K motor? Tue, 06 August 2002 05:36 Go to previous messageGo to next message
thanx guys i have all ur ideas have done me well thats what that little 4k's gonna get after i get some money together i will do the 4ag translpant how hard is it to adapt those motors and what would i have to modifie to get it through engineering??
4-AGE.T-18
Re: How can i work my 4K motor? Sat, 10 August 2002 12:43 Go to previous messageGo to next message
shave 60 thou off ya standard head...$30.00
Buy a second hand 1800 cabie from a honda civic...$20
Get a set of extractors that flow really well...$200
Find an electronic ignition module ...$100 or so
Run hotter plugs after the head is done
run thermo fan instead of one on motor.
If ya cant find electronic ignition advance the hell out of yours
It will rattle like shit but hey its only a 4k and itll go better
P.S. the carby bolts straight on.
Sean
Apollo
Brisbane, QLD, Australia
Re: How can i work my 4K motor? Sat, 10 August 2002 13:43 Go to previous messageGo to next message
4-AGE.T-18 wrote on Sat, 10 August 2002 10:43 PM
Sean
The electronic ignition is worth that much?
DAMMIT!!
I ended up throwing mine away that was in good condition because noone wanted it.
As for the 4k, why? Why not a 5k instead? Physically the same, but a 1500 instead of a 1300.
Kiwi Jake
Narellan
Re: How can i work my 4K motor? Sun, 29 September 2002 09:34 Go to previous messageGo to next message
I have a fully rebuilt (new throttle shafts, butterflies, slides etc)pair of SU carbs on a manifold to suit K series motors. Manifold painted in 2 Pak black and carbs in magenta. Give us a yell if you want them. p.s all brand new linkages as well. Cost me a fortune at the time and I never ended up using them anyway. They are just collecting dust now so I'd sell the lot pretty cheap.
5KinKP60
Finland
Re: How can i work my 4K motor? Sun, 29 September 2002 11:59 Go to previous messageGo to next message
Strip ignition distributor into bits. Limit advance mechanism travel movement. Original has too wide operating range for a tuned engine (i.e. sporty camshaft grind installed). You need more advance in idle/lower rpm range - but about the same advance as standard engine when in high rpm.
Rough guide - set idle advance to about 12 to 16 degrees BTDC. Make all advance come in at about 3500 to 3800 rpm. Max total advance about 34 degrees.
Experiment with one distributor bob weight only, stuff the stronger spring (most likely).
That will make engine run _much_ smoother than ridiciously advanced standard distributor mechanism, and will make more power too. Also having std distributor advanced like there is no tomorrow will help engine to knock under acceleration. That's no good.
-A.
corolla coupe 18rgu
Townsville NQ
Re: How can i work my 4K motor? Mon, 30 September 2002 11:47 Go to previous messageGo to next message
Hey Jake where are you, what size are the carbs and how much you asking
physh
Re: How can i work my 4K motor? Mon, 30 September 2002 12:32 Go to previous message
kiwi jake... sent you mail yesterday... Smile
Previous Topic:3tgte head tension
Next Topic:MR2 Radiator
Current Time: Thu Oct 29 07:35:44 UTC 2026
Total time taken to generate the page: 0.10816788673401 seconds
