Toymods » Tech & Conversions » easiest way to check inlet valves are working?
Chris Davey
sunny coast, qld
easiest way to check inlet valves are working? Mon, 26 January 2004 03:50 Go to next message
In my 5 cylinder 1jz-gte I have narrowed the issue down to no fuel or no air. I will be checking the injector this arvo and I was told one way of checking to see if the inlet valves are opening.
I was told to get a piece of wire with a small right angle at the end of it, place it in the spark plug hole facing the inlet side and turn the harmonic balancer around until it gets to the inlet stage and i should be able to feel the valve pushing the wire down slightly. Does this sound like a good idea? Any other ways besides pulling the head off?
Chris
ThatDogsFullySickMate
BrisVegas---YeeeHAW
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 05:15 Go to previous messageGo to next message
i would pull the head off anyway as it could be something else that is your problem, such as collapsed water jacket making a cylinder not fire anyway, and if it wasnt at least you would be able to see all the valves moving, or possibly they are moving but one or two are bent
better to know for sure than to guess and hope
tony
ed_ma61
Lost in the K hole
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 09:32 Go to previous messageGo to next message
sounds a bit unlikely that the valves arent opening...
i mean, is an overhead cam engine, theres not a whole lot getting in the way of the cam opening the valve. simply taking off the cam cover and watching the cam rotate onto the valve bucket should be enought to tell you whether its working or not.
id be much more inclined to check the fuel injector - more likely its buggered/stuck/malfunctioning than no air getting in.
have you checked spark? checked the coils? checked signal to the coils?
have you pulled the plug and coil out and watched it spark to earth?
i say youve got a bloody long way to go before having to pull the head off
Chris Davey
sunny coast, qld
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 10:33 Go to previous messageGo to next message
I just checked the spark, coils and the signal to the coils and they were all good.
Compression is good in all cylinders.
I pulled the plug out and it was sparking when on the ground.
I unplugged the coil and ran the car for a second and then pulled the plug out and there was no fuel on it. So then i pulled the plug out and ran it for a sec and there was no mist coming out of the plug hole.
Then i checked that there was power on the terminals for the plugs and the cylinder that isn't firing had the same as another one. This leads me to believe that the injector is clogged or something.
I am going to start a new thread on the removal of the injector.
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 10:38 Go to previous messageGo to next message
if compression is good, then air is getting in ok.
if you have spark, then it can only be fuel.
get a long screwdriver and put the end on the injector in question while engine is running. put your ear on the other end (the big end Razz ) and you should easily hear if it is clicking or not.. check against the others..
if in doubt, take them to get checked by a decent injector servicing shop. get them cleaned anyway Wink
undo fuel rail. pull injector out?
BrisVegas---YeeeHAW
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 11:29 Go to previous messageGo to next message
undo your tank fuel cap before unplugging injectors, this will release pressure in the fuel system and avoid you getting a squirt of fuel everywhere
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 11:39 Go to previous messageGo to next message
how will undoign the fuel tank cap help? any retained pressure will be in the section of line between the fuel pump, injectors, and fuel pressure reg....
V8_MA61
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 11:52 Go to previous messageGo to next message
unless your springs are shot, theres no way of your vavles not working properly Confused
[Updated on: Mon, 26 January 2004 11:52]
ed_ma61
Lost in the K hole
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 11:55 Go to previous messageGo to next message
ThatDogsFullySickMate wrote on Mon, 26 January 2004 22:29
wtf are you smoking?
http://board.performanceforums.com/forums/images/smilies/wtf.gif
if you want to depressurise the fuel system, start the car, then remove the efi fuse from the main relay/fuse box in the bay. the engine will soon die. try starting it several times (it should splutter and die, and eventually do nothing but crank over)
THAT is how you depressurise the fuel system Rolling Eyes
BrisVegas---YeeeHAW
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 12:11 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 26 January 2004 22:55
tyres ?
i had a ra65 with the pump in the tank the haynes manual said that is how to depressurize a system ?
ed_ma61
Lost in the K hole
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 12:20 Go to previous messageGo to next message
ThatDogsFullySickMate wrote on Mon, 26 January 2004 23:11
tyres ?
Laughing Laughing
you gotta wonder about haynes sometimes Rolling Eyes
BrisVegas---YeeeHAW
Re: easiest way to check inlet valves are working? Mon, 26 January 2004 12:26 Go to previous messageGo to next message
i dont know im just a chef !
purpleminiep
Mentone
Re: easiest way to check inlet valves are working? Tue, 27 January 2004 03:46 Go to previous messageGo to next message
with a very nice hair cut Laughing
BrisVegas---YeeeHAW
Re: easiest way to check inlet valves are working? Tue, 27 January 2004 03:55 Go to previous messageGo to next message
its max headroom
drink coke and be refreshed
Re: easiest way to check inlet valves are working? Tue, 27 January 2004 10:19 Go to previous messageGo to next message
ThatDogsFullySickMate wrote on Tue, 27 January 2004 13:55
its max headroom
dont you mean to say:
dr dr dr drink coke and and and and be and be refrershed ../
BrisVegas---YeeeHAW
Re: easiest way to check inlet valves are working? Tue, 27 January 2004 10:32 Go to previous message
C-c-c-catch the wave
Previous Topic:ae93 clutch --PLEASE HELP
Next Topic:2TGEU Running Microtech digi 1 Help
Current Time: Wed Oct 28 06:13:00 UTC 2026
Total time taken to generate the page: 0.005551815032959 seconds
