Toymods » Tech & Conversions » GZE belt slip
old_mr2
icon8.gif  GZE belt slip Mon, 26 January 2004 08:42 Go to next message
Guys
my aw11 gze is suffering from SC belt slip. When I go over 4500 rpm, when im giving it a bit, the SC belt begins to slip. (screeching sound as well as cccchhhh sound)
I believe this us a common problem among GZE owners. I was wondering If any one had any tips on tightening the belt from under the car. Any help will be much appreciated as I wanna smash some more commodores.
Tools available: Socket set and other basic tools.
Is a tensioning gauge nescessary, If so how much??
feral4mr2
Bundaberg, Qld.
Re: GZE belt slip Mon, 26 January 2004 11:55 Go to previous messageGo to next message
Freak you need a 14mm ring spanner to losen the lock nut on the idler/tensioner pulley. a 14mm socket with some looong extensions and your ratchet.
you dont really need to jack the car up, depends if you like laying down on ya back and reaching under.. Laughing (well you gotta get on your back anyways even if its jacked up).
get/reach under and losen the idler nut with your ring spanner, dont take it off just losen it.
take out your dipstick, you will see a bolt head down there, thats where your 14mm socket goes and the extensions so you can put your ratchet on it (helps if you have one of them knuckle type ends on your extension on the socket so it can move/swivel a bit).
by memory turn the ratchet clockwise to tighten the bolt/tensioner. make sure you tighten the idler locking nut up tight when you are happy with the belt tension.
Smile
old_mr2
Re: GZE belt slip Mon, 26 January 2004 11:59 Go to previous message
awesome
thanks feral for the detailed response. You're the best.
I cant wait to give it a go in the morning.
cheers Razz
Previous Topic:identify these wheels please...
Next Topic:1jz timing belt..help?
Current Time: Sat Oct 31 14:43:41 UTC 2026
Total time taken to generate the page: 0.095112800598145 seconds
