Toymods » Tech & Conversions » 1jz - removing injector?
Chris Davey
sunny coast, qld
1jz - removing injector? Mon, 26 January 2004 10:35 Go to next message
Is there any way of pulling the cylinder 3 injector out without having to pull the whole fuel rail out?
If not, what is the easiest way to pull the fuel rail out? Do you need to pull the inlet manifold off?
I was thinking of taking the throttle body off and then disconnecting the vacuum plugs and possibly I would be able to get it off then. What do you think?
Re: 1jz - removing injector? Mon, 26 January 2004 11:13 Go to previous messageGo to next message
bassaholic55 wrote on Mon, 26 January 2004 21:35
No.
Take the top half of the intake manifold off. Then you can get to the fuel rail easily. This will open up runners (and they are opportunely positioned so they face slightly upwards ready to catch any stray bolt that might come their way) so be sure to plug them with clean rags to prevent grief.
ed_ma61
Lost in the K hole
Re: 1jz - removing injector? Mon, 26 January 2004 11:20 Go to previous messageGo to next message
what he ^^^^^^^ said Smile
although theres A LOT you can do before taking the injectors out.
have you switched injector plugs over to see if the dodgy cyl now fires (and the one you switched the suspect lead onto doesnt fire?)
also get a 5v battery and connect it to the terminals of the injector (without taking it out) and listen for the 'click click' of the injector solenoid opening and closing.
then once youve CONFIRMED its dead (one way or another as above) then go to the hassle of disassembling theintake manifold Smile
ed
Soarer
Wollongong
Re: 1jz - removing injector? Mon, 26 January 2004 11:44 Go to previous messageGo to next message
*Ahem*... the two posts above are incorrect.
In the last 2 weeks, I have removed and replaced the injectors in my 1JZ-GTE twice. The only things I removed were the accelerator and kickdown cables. Everything else was done with either my fingers or a ring spanner.
I didn't touch the IACV or loosen the inlet manifold.
Mind you, it helps to have *very* flexible fingers.
All in all, I think it took me 1h 45m to remove the 380cc injectors and install the 440cc ones.
Soarer
Wollongong
Re: 1jz - removing injector? Mon, 26 January 2004 11:45 Go to previous messageGo to next message
By the way, the first 3 injectors are the easiest to pull out. I could remove and replace those in 30 mins now I reckon. It's the back 3 that are the tough ones.
ed_ma61
Lost in the K hole
Re: 1jz - removing injector? Mon, 26 January 2004 11:47 Go to previous messageGo to next message
ok, stand corrected...
BUT you should still check the injector function before trying to rip them all out.
sideshow
Re: 1jz - removing injector? Mon, 26 January 2004 11:59 Go to previous messageGo to next message
get a long screwdriver and put sharp end onto injector and blunt end onto yr ear
with engine runnin
u should hear it tick
if not get a noid light and see if the injector is gettin a pulse from ecu
if no pulse then the wiring is broken somewhere
the injectors are pulsed in pairs so if one injector has broken wire usually another injector would be down aswell
if only one injector aint workin it could be wiring broken right near injector
another prob could bve just a stuck injector from engine sittin round for months
run an earth to one pin on injector and do tiny zaps with 12v on the other injector
this is like jump startin the injector
while u r zappin get someone to tap injector with a screwdriver of small hammer
this is very common on jap engines for injectors to stick closed
Chris Davey
sunny coast, qld
Re: 1jz - removing injector? Mon, 26 January 2004 23:37 Go to previous messageGo to next message
i have checked that there is power going to the plug on the injector that is not firing and it is the same amount of power going to a plug that is firing so I am 99% certain that it is clogged.
Soarer: you saying you didn't pull the whole fuel rail out or not?
I am a newby at this so...how exactly do you pull the injector out of the rail? ie what holds it in?
Soarer
Wollongong
Re: 1jz - removing injector? Tue, 27 January 2004 00:30 Go to previous messageGo to next message
I didn't pull the fuel rail out at all. When you remove the electrical connectors and accelerator cables, you will be able to see a long metal plate holding the injectors into the rail (there are 2 separate plates, one for the first 3 injectors, one for the rear 3).There are three 10mm bolts holding the plate over the injectors. Remove the 3 bolts, then you can just pull each injector out at will.
Chris Davey
sunny coast, qld
Re: 1jz - removing injector? Tue, 27 January 2004 01:40 Go to previous messageGo to next message
thanks heaps mate. I will have a go at it tonight! Smile
82MKII
Re: 1jz - removing injector? Tue, 27 January 2004 05:31 Go to previous messageGo to next message
Guys - what a timely thread!
I have a 1J that's been sitting around (not started) for quite a few months and was thinking about pulling the injectors to have them cleaned/flow tested.
Thanks for the info.
Peter
speakafreaka
Re: 1jz - removing injector? Tue, 27 January 2004 06:35 Go to previous messageGo to next message
can any of you 1j guys lend me their map sensor to test if mines buggered? i dont need to take it anywhere, just swap mine then take it for a run then swap back.
i posted in parts wanted, but im not sure how many people check there
http://forums.toymods.org.au/index.php?t=msg&t h=27914&start=0&rid=2392&S=ccf12835df2 52f15085d610a88d2dfc2
Re: 1jz - removing injector? Tue, 27 January 2004 06:43 Go to previous messageGo to next message
soarer is in the gong, mine doesn't have a map sensor... you could try luke, if he's still around
I have an ignitor - does that help? Razz
[Updated on: Tue, 27 January 2004 06:44]
speakafreaka
Re: 1jz - removing injector? Tue, 27 January 2004 06:46 Go to previous messageGo to next message
they (hills ms) checked the coil packs and they were all good, so they eliminated that.. they were going to try replacing the map themselves, but i couldnt afford an extra hour Nope
Soarer
Wollongong
Re: 1jz - removing injector? Tue, 27 January 2004 07:41 Go to previous messageGo to next message
Not sure when I'll be in the Earlwood area next, but I know someone with a 1J in the area. I'll see if he's got time for you to test with his.
speakafreaka
Re: 1jz - removing injector? Tue, 27 January 2004 07:43 Go to previous messageGo to next message
Thanks guys
Chris Davey
sunny coast, qld
Re: 1jz - removing injector? Tue, 27 January 2004 07:58 Go to previous messageGo to next message
Speakafreaka: what are the symptoms your 1jz has? Are they similar to mine?
Mine: only runs on 5 cylinders all the time but feels a bit better when the revs go up.
Chris
speakafreaka
Re: 1jz - removing injector? Tue, 27 January 2004 08:21 Go to previous messageGo to next message
it missfires terribly when its approaching full boost (~9psi).
i changed the plugs twice trying different combinations over the last few months, and i thought it may be an overfuelling problem from the ECU supplying too much gas, which is the main reason i bought an SAFC.
When they (Hills MS) were tuning it they checked the fuel pressure (ok) coil packs (ok) and sparks (ok). they seemed to think it felt like it was hitting boost cut.. they were gonna try another map sensor but as i said above i just didnt have the cash today.
ive had a little search through google, and it seems others are having the same problem
im hoping its that.. because im running out of ideas.
Chris Davey
sunny coast, qld
Re: 1jz - removing injector? Tue, 27 January 2004 08:28 Go to previous messageGo to next message
oh ok, well my problem is definitely different to yours then.
I really hope it is just a clogged injector.
Going to see if I can fix it/get it out now.
Thanks for the help everyone Smile
Chris Davey
sunny coast, qld
Re: 1jz - removing injector? Tue, 27 January 2004 10:48 Go to previous messageGo to next message
SIDESHOW you are a champion!!!! I did the jump starting the injector thing and it started running properly nearly straight away!!!!! I am so happy Smile Sounds good and runs nice and smooth like a 1jz is supposed to. Thanks again mate, saved me heaps of time and some money too!
On the down side, my first 6 cylinder drive ended a bit strangely when i went over a pot hole and the electrics started going a bit funny. Got a short somewhere. I have just found it though so I will go and fix that.
Now all I have to do is stop the damn handbrake cable dragging on the tail shaft!
Thanks again
[Updated on: Tue, 27 January 2004 10:50]
sideshow
Re: 1jz - removing injector? Tue, 27 January 2004 12:30 Go to previous message
thats good to hear
about 30 to 40% of jap import engines i have wired up have this prob
i have my own little tool for jump startin the injectors
i do it from the ecu
i did a maz v6 the other day took me 30 mins to get all injectors workin
they were fukin seized big time
Previous Topic:Turning starter upside down
Next Topic:aw11 arm-rest
Current Time: Thu Oct 29 14:50:01 UTC 2026
Total time taken to generate the page: 0.090995788574219 seconds
