Toymods » Tech & Conversions » Turning starter upside down
Turning starter upside down Mon, 26 January 2004 11:28 Go to next message
I've got a RWD 4AG with one of those hideous dellows bellhousings. It has a starter motor 'place' on both sides, so is there any reason I can't turn my 4AC (LHS) starter upside down and mount it on the RHS? Everything appears to line up just fine, and finding a 'real' AE86 4ag starter is probably going to be quite a task. Has anyone tried this?
ChuckLandwehr
Re: Turning starter upside down Mon, 26 January 2004 12:20 Go to previous messageGo to next message
No I have not done it! but if it fits, there is absolutly no reason why you can't mount it upside down.
regards Chuck.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Turning starter upside down Mon, 26 January 2004 12:22 Go to previous messageGo to next message
I don't know how, why or what, but my starter's got a little rubber drainage tube underneath it pointing straight down, which doesn't really look like the sort of thing that should be repositioned pointing up (assuming all starters/all 4age starters have the same thing).
Does anyone know why it's there & what it's for? Maybe it's just a breather positioned to avoid water or dirt entering, in which case it could be modified to suite?
Re: Turning starter upside down Mon, 26 January 2004 12:52 Go to previous messageGo to next message
Yeah, I noticed this, and was going to be nice enough to plug the hole up and move it to the other side. Evil or Very Mad
._T_.
Re: Turning starter upside down Mon, 26 January 2004 21:43 Go to previous messageGo to next message
in the prb's we end up mounting the 20v starters upside down. does not seem to cause any issues. & yes moving the drain woul be a good idea!!
T
Re: Turning starter upside down Tue, 27 January 2004 12:02 Go to previous messageGo to next message
Dang. I'm an idiot! What the HELL was I talking about a 'genuine 4ag' starter for? I was getting clutch cylinders and starter motors mixed up! I really should not come on here after my bedtime, ey...
Anyways, I took the inlet off today, and took a closer look - it appears that the drivers side starter hole is designed to fit a FWD starter anyway.... YAY!!!! So, no upside down, and an endless supply of spare starters for stuff all $. Could it be that dellows ACTUALLY got something right? Evil or Very Mad
Necros
Re: Turning starter upside down Tue, 27 January 2004 12:14 Go to previous messageGo to next message
Im guessing the 4AGE AE86 starters are mounted on the right hand side?
The reduction starter motor from a AE92 fits in place of the std 4AC starter too ;p Im running one...
Re: Turning starter upside down Tue, 27 January 2004 12:33 Go to previous message
Noooo... that's what I meant when I said I was an idiot, the AE86 starters are ALL LHS...
When I said FWD starter, I mean the reduction starter that has the wider/offset bolts, e.g. GZE, AE92 on 4Aeverything, far as I know.... Anyways, I know there's dozens of them around and they're not exactly in demand. And they make it sound like a freaking hilux Evil or Very Mad
Previous Topic:carby vacum leak/brake booster
Next Topic:1jz - removing injector?
Current Time: Thu Oct 29 16:53:04 UTC 2026
Total time taken to generate the page: 0.049360036849976 seconds
