Toymods » Tech & Conversions » Force inducting an NA motor
wagonist
Toymods Club Treasurer
icon5.gif  Force inducting an NA motor Mon, 26 January 2004 22:28 Go to next message
Having never looked at doing this before, I'm wodering what the pitfalls are in applying forced induction to an NA motor, I've always just bought the turbo straight out.
I know that if the boost is kept low, say 6psi or so, that generally the NA motor can be left untouched,
but...
we all also know that I'll want to wind the boost up later, so am I better off rebuilding a motor before I put it in, or waiting until I can afford to add the turbo/supercharger & doing it then.
The motor I thinking about is a 1MZ 3.0L V6 (Camry, Lexus ES300)
The things I know that I should do are:
forged pistons with lower compression, say between 8:1 or 9:1 (does anyone know compression is standard?)
Add an intercooler.
Anything else I need?
What would be the deal with the map sensor?
Will it run out of range with the boost?
If I change it to one from a turbo car, say GT4, will the computer then get the right readings?
10sec_rx7
Syndey
Re: Force inducting an NA motor Mon, 26 January 2004 23:35 Go to previous messageGo to next message
i have done it heaps of times,
im running 15psi on my misses starlet with the stock 4efe (non turbo aus motor) motor in it,
and on a 4age running 11psi no problems at all,
its all in the tune, if the tune is bad the motor will blow, if the tune is good it will be fine,
dont waste your time with factory ecu's the toyota ones are very very hard if not impossible to retune, go straight for a after market!
Dale
slydar
Re: Force inducting an NA motor Tue, 27 January 2004 00:39 Go to previous messageGo to next message
depends on the motor. some engines have really weak rods which are unsuitable for forced induction, e.g b16 honda. you will also need to plumb oil and water feed and return lines. youd definately need some type of programable efi. like 10sec said, the tuning is very important, especially on an engine never intended to be force fed which will inherantly have less margin for error (due to its weaker internals).
Re: Force inducting an NA motor Tue, 27 January 2004 01:47 Go to previous messageGo to next message
you'll want to look at your cooling system as you're going to add more heat into it that designed for.
even if it's only improving the air flow to the radiator, or something more substantial like extra fans.
might be worth talking to a radiator place to see if there's aa heavy duty item you can run.
carefully plan your water lines to/from the turbo - you want it flowing regardless of state of the state of the thermostat (e.g. cool fluid from lower block, hot fluid into top pipe after the thermostat)
plus oil cooling will help - whether it's the donut cooler/heater at the oil filter - or an external unit out the front. FWIW: i'm using an external trannie-cooler to take the heat out of oil going to the turbo - it's not a full-flow cooler.
And if you're going to put an aftermarket ECU that has an RS232 or USB port, get a cheap laptop to help with tuning - otherwise you have to use an auto-elec or dyno shop everytime you want to tweak the system.
isaac
Helensvale, Queensland
Re: Force inducting an NA motor Tue, 27 January 2004 03:33 Go to previous messageGo to next message
Hmm, i am thinking about turbo'in' my 5sfe. I realise i can do a 3sgte swap but i want to be different. I am thinking of getting the exhaust manifold, turbo and top mount intercooler off a 3sgte and slapping it on my car. If i just left the car as is otherwise (EG: stock internals, stock ecu, stock injectors etc) what would happen as the car trys to drive like normal, but has boost?
10sec_rx7
Syndey
Re: Force inducting an NA motor Tue, 27 January 2004 03:40 Go to previous messageGo to next message
tryed that on my misses car, we fitted the turbo etc at the workshop then i took it home to fit the computer on the drive home as soon as you think about coming onto boost it will ping its nuts off and then will just hit a brick wall and go no where,
not a good thing, lucky we had to only drive 2km!
here are some pics on the conversion we did on the starlet
http://www.users.bigpond.net.au/dheiler/dyno/starletcooler1.jpg
http://www.users.bigpond.net.au/dheiler/dyno/starletcooler2.jpg
Dale
feral4mr2
Bundaberg, Qld.
Re: Force inducting an NA motor Tue, 27 January 2004 08:12 Go to previous messageGo to next message
Freak Dale, what pump do you like to use with the w2a i/c's?
crazy_camry
Re: Force inducting an NA motor Tue, 27 January 2004 08:58 Go to previous messageGo to next message
on www.toyotanation.com, a member, "Tony the Tiger" has turboed his 1MZ with great success. get into contact with him about specifics.
10sec_rx7
Syndey
Re: Force inducting an NA motor Tue, 27 January 2004 09:27 Go to previous messageGo to next message
feral4mr2 wrote on Tue, 27 January 2004 19:12
im using a davis craig booster pump with it, works well and is very very quite,
personally i wouldnt do another water to air on a street car they are too much mucking around for the very small gains you get, you still have to mount a water cooler, then pipe it all up the only advantge i have found is in stop start traffic...on the freeway a air to air shits all over the water to air.
Dale
[Updated on: Tue, 27 January 2004 09:27]
midnight
Re: Force inducting an NA motor Tue, 27 January 2004 11:54 Go to previous messageGo to next message
you can also get thick metal gaskets that work as a decompression plate.
Re: Force inducting an NA motor Tue, 27 January 2004 14:27 Go to previous messageGo to next message
Decompression plates (or thick gaskets) are a BAD idea when you're talking about modern engines which are designed to make use of quench area. Reduce that quench area and you'll end up with an engine that pings more, not less!
Re: Force inducting an NA motor Wed, 28 January 2004 04:07 Go to previous messageGo to next message
jeez - imagine 2 custom-made metal gaskets - o-rings, machining , etc -
btw, if you go metal spacer plate you'll become very adept at replacing blown head-gaskets - 4 all up as you're going V6?
tho - your local spare parts shop will know you by name tho ...Wink
wagonist
Re: Force inducting an NA motor Fri, 20 February 2004 01:51 Go to previous messageGo to next message
Where is "Tony the Tiger"?
I managed to find a wrecker this morning with 4 1MZ-FE's on the shelf & one still in an 01 Camry.
$1200 for a bare motor, $1800 with wiring.
Still have concerns about fitting this to my car.
The engine mounts are completely different.
ie 2 mounts either side of engine half way like a RWD setup instead of one on each side like my car.
Plus it think it's going to be hard to fit a 4wd gearbox without massacring the rear exhaust headers. Mind you if I go turbo, this have to be done anyway.
crazy_camry
Re: Force inducting an NA motor Sat, 21 February 2004 01:32 Go to previous messageGo to next message
wagonist wrote on Fri, 20 February 2004 12:51
he is on www.toyotanation.com most of the time on the camry forum. have a search round there.
crazy_camry
Re: Force inducting an NA motor Sat, 21 February 2004 01:43 Go to previous message
i found his homepage for you:
http://www.geocities.com/leunghomepage/
Previous Topic:east-west engined Gearbox q
Next Topic:RA60 21R-C Manual Conversion
Current Time: Thu Nov 5 03:56:20 UTC 2026
Total time taken to generate the page: 0.18144297599792 seconds
