Classifieds » Parts Wanted » Fan from 2tg
stylez
Fan from 2tg Tue, 27 January 2004 01:02 Go to next message
im after the fan from a 2tg,
my 2t fan is the wrong size,
CLG
Perth, Western Australia
Re: Fan from 2tg Tue, 27 January 2004 02:03 Go to previous messageGo to next message
I have a few T series clutch fans here, can you specify the size you want?
stylez
Re: Fan from 2tg Tue, 27 January 2004 10:41 Go to previous messageGo to next message
i had some pictures in the other thread i made about this
http://forums.toymods.org.au/index.php?t=msg&t h=27569&rid=1556&S=294b32131c2a5ed26b687ac 9989cffeb&pl_view=&start=0#msg_239107
i can get measurements of bolt holes tomorrow, but its the fan with wide bolts hole spacing, and a fan that comes out a long way, so that it can clear the front of the motor, given that the fan hub is almost in line with the front of the motor,
the pictures should make it more clear.
stylez
Re: Fan from 2tg Fri, 30 January 2004 12:00 Go to previous messageGo to next message
no one has a 2tg fan lying around?
Sad
CLG
Re: Fan from 2tg Fri, 30 January 2004 12:04 Go to previous messageGo to next message
No, still waiting for the measurements? Rolling Eyes Smile
Jonny2TG
Tasmania
Re: Fan from 2tg Mon, 02 February 2004 14:06 Go to previous messageGo to next message
OK I have done this.
You have a 3T or late model 2T-GEU waterpump with the large fan bolt spacing. You need a thermo fan off a 3T engine, or a late 2T-G (some other toyota fans would fit also). The 3T fan will fit, and is the same as the 2T-GEU one. I have one, but I think the clutch is gone.
OR. You could use the fixed blade fan you already have, like on a early 2T-G. The fixed blade fan is the same as on 4K engines. You just need to use the waterpump and pulley of a old 2T motor, and the fixed blade fan will bolt on.
I have done both.
CLG
Re: Fan from 2tg Mon, 02 February 2004 14:49 Go to previous messageGo to next message
that said, I've got three 3T fans here, if you still need one?
stylez
Re: Fan from 2tg Tue, 03 February 2004 07:39 Go to previous message
sorry, been down the coast for a few days,
the bolt spacing is ~40mm from one bolt to the next, or ~60mm diameter for the circle formed by the 4 bolts.
for fan clearance there is no room for fan blades to extend backwards from the bolting surface, otherwise they will hit the front of the motor.
so if you look at the fan side on, it should extend forward from where the line of the bolt holes.
does that make any sense? do the the 3t fans fit that requirement ?
thanks for your time fellas.
Previous Topic:5k or 7k wanted
Next Topic:Wanted-AE86 axle hub
Current Time: Thu Nov 19 08:08:17 UTC 2026
Total time taken to generate the page: 0.0098979473114014 seconds
