Toymods » Tech & Conversions » 3TGTE ignition leads
tanman
3TGTE ignition leads Mon, 05 August 2002 10:54 Go to next message
Well I figured out why my engine is running rough. I went to watch a mate hillclimb his old datto GTR on the weekend and the access road to the track was like the surface of mars (I needed a hilux lift kit on the TA22). Anyway the dizzy end of my no.1 plug lead is MIA and I need a new set of leads. I have been quoted $165 for a set of Top Gun 8.0mm silicon leads. Are these leads ok or should I get soemthing else? something not too expensive though. As those sort of prices should be left to those dirty datto drivers.
Guest
Re: 3TGTE ignition leads Mon, 05 August 2002 11:14 Go to previous messageGo to next message
Stephen, I hope thats not the magnacore leads that have stuffed up!!
If so I would call the guys at thundercords and get them to repair them, they are a VERY expesnive set of leads!!! (I paid $200 (mates), standard v8 set is 300+ )
Custom made for THAT car, only a couple of months before you aquired it.
dont throw them away you wont improve on then once repaired !
Matt
Jonny2TG
Tasmania
Re: 3TGTE ignition leads Mon, 05 August 2002 11:15 Go to previous messageGo to next message
I have Top Gun leads on my 2TG. The engine runs. I get a big zap from the leads if I get too close. I don't know if that is good or bad. The engine does not run at 100% all the time, but I don't think the leads are at fualt.
Guest
Re: 3TGTE ignition leads Mon, 05 August 2002 11:16 Go to previous messageGo to next message
Top gun are shit !!! (compared)
Matt
tanman
Re: 3TGTE ignition leads Tue, 06 August 2002 10:24 Go to previous messageGo to next message
Matt, it was the Magnecor lead which broke. I will get a new lead made up by Thundercords thank for your help. My mechanic mentioned that they were good leads and looking at the magnecor web site they sound pretty damn good. Ultimately I will remove the distributor altogether though to fit a custom plenum. I will fit a hall effect sensor and run coil packs. I will do all this when my recently aquired ROSS forged pistons get fiited next year.
Guest
Re: 3TGTE ignition leads Tue, 06 August 2002 10:50 Go to previous messageGo to next message
Stephen,that is the way to go, callthem , I cant remember the guys names anymore but they were extremelyhelpful, tell them what happened, email them even, they will reply almost immediately.
Matt
tanman
Re: 3TGTE ignition leads Thu, 08 August 2002 11:07 Go to previous messageGo to next message
Well I rang the guys at Thundercords on Wednesday morning and had a replacement lead by Thursday arvo. The guys there are friendly and extremely helpfull. It only cost my $20 plus postage. So I cleaned and gapped the plugs put the leads on and fired up the 22. It ran noticeably better but still had a chunky exhaust note. Took it for a quick drive to see if it would clear, still no joy. I then began to fault find the ignition system and found that one of my coils has failed (the other one went about 5 months ago). So tommorow I will buy a new coil and it should be troublefree motoring again.
Karl_skewes
New Zealand
Re: 3TGTE ignition leads Sat, 10 August 2002 10:37 Go to previous messageGo to next message
yep, I wouldn't rate my top Gun 8mm. leads. about 8K ohm resistance each....... however my EAGLE leads have about 1K ohm resistance. !!!! excellent. and sold by APPCO. Not too expensive either. $80 a set or something
Guest
Re: 3TGTE ignition leads Sun, 11 August 2002 00:10 Go to previous messageGo to next message
Stephen , you didn't jump start it did you ??
lvn-ra65c
Wichita, Ks, USA
Re: 3TGTE ignition leads Mon, 12 August 2002 21:04 Go to previous message
anyone have a picture of the Thundercords for the 3tgte?
how much did the set cost?
Previous Topic:4AGE Throttle position sensor wiring
Next Topic:front lower arm bushes
Current Time: Fri Oct 23 21:40:01 UTC 2026
Total time taken to generate the page: 0.0047450065612793 seconds
