Classifieds » Parts Wanted » 1JZ-GTE MAP sensor
speakafreaka
1JZ-GTE MAP sensor Tue, 27 January 2004 05:17 Go to next message
http://members.optusnet.com.au/~soopfly/safc/2.JPG
i need to borrow a standard 1j map sensor.. just to see if mine is causing a faulty reading as im hitting boost cut way too early. (previously thought to be missfiring.. exhausted all possible problems there)
a reward will be given in the form of alcohol (if you drink)
thanks Very Happy
[Updated on: Tue, 27 January 2004 05:17]
speakafreaka
Re: 1JZ-GTE MAP sensor Wed, 28 January 2004 07:59 Go to previous messageGo to next message
It reads
SENSOR ASSY TURBO PRESSURE
TOYOTA
89420 - 22140
100798 2232
5V
DESNSO JAPAN
if no one can lend me thiers for five minutes in front of their place of residence, can anyone let me know how much they are?
slylux
perth WA
    nup
Re: 1JZ-GTE MAP sensor Thu, 05 February 2004 12:43 Go to previous messageGo to next message
still chasing a map sensor ??
grande91
Re: 1JZ-GTE MAP sensor Fri, 06 February 2004 13:45 Go to previous messageGo to next message
how much is too early speakafreaka??? and by the way what ever happened to cressida.com ......
speakafreaka
Re: 1JZ-GTE MAP sensor Sat, 07 February 2004 10:47 Go to previous messageGo to next message
its weird.. about 8psi but it still pulls a bit and clears out at about 12psi.
its the next thing to try to see if its the problem
speakafreaka
Re: 1JZ-GTE MAP sensor Sat, 07 February 2004 10:49 Go to previous messageGo to next message
yeah therm ran into problems copying over the forum, lost everything that was posted past september 03.
its at www.toyotacressida.com/forum at the moment, but its a beetch to login to.
grande91
Re: 1JZ-GTE MAP sensor Sat, 07 February 2004 13:55 Go to previous messageGo to next message
ur sure its not missing at that point????
speakafreaka
Re: 1JZ-GTE MAP sensor Sat, 07 February 2004 21:23 Go to previous messageGo to next message
*deep breath*
well.. that what i originally though, but after changing plugs twice, and decreasing the gap i knew it was something else.
i had my safc dyno tuned, and they couldnt completely tune it because of the problem, so they started to eliminate possibilities.
Coils: fine
fuel pressure: fine
(then they started thinking it felt like a boost cut)
so they looked at the map sensor, but at this point i couldnt afford to pay them anymore.. ($88/hour) so they said it could be the map sensor, so test it.
the other thing that worries me is the amount of soot that blows out of the exhaust when i start it.. my dads front bar gets covered in it when i start the car with him parked behind... gives me the impressiong its got some blown seals.. hills motorsport didnt pick it up, but i didnt say anything about it either.
theres just so many things that could be causing it its annoying.
SUPRA MAN
Re: 1JZ-GTE MAP sensor Sun, 08 February 2004 03:21 Go to previous messageGo to next message
speakafreaka wrote on Tue, 27 January 2004 16:17
thanks Very Happy
speakerfreaka---> You can borrow mine if you want, just organise a time to come over with Dan and you can grab one off my soarer and try it....
speakafreaka
Re: 1JZ-GTE MAP sensor Sun, 08 February 2004 05:56 Go to previous messageGo to next message
thanks for the offer dude.. ill let you know
SUPRA MAN
Re: 1JZ-GTE MAP sensor Sun, 08 February 2004 05:59 Go to previous message
ok.....
Previous Topic:ra40 lh front guard WANTED
Next Topic:WTB - AE92 SX Spolier and Rear Disc setup.
Current Time: Fri Oct 16 13:04:58 UTC 2026
Total time taken to generate the page: 0.0064318180084229 seconds
